Please ID these punches
broncoman1972
I found these punches when going through a box of tools from my grandfather. The 3 smaller ones, sizes #8, #10 and 1/4, have the word TAMPIN stamped in them before the size. The only marking I could find on the largest one is a diamond stamped on the side.
Who here can tell me what these are used for?
Sent on the fly
sk farmer
nd
if the center punch is free in the outer part, they are used to find the center of a hole when drilling a hole when two parts are laid together. center the round outside in the hole, punch the center and you have found the exact center to drill on.
broncoman1972
Would they have something to do with these?
In my searching I couldn't find the punches but found these called tampin anchors. Looks like they could be related. Also, I found quite a few of these in various places in his stuff.
Sent on the fly
broncoman1972
Nope. Not spring loaded. And, unless they're seized from lack of use the center part is rigid with the outer part. Sk farmer may be on to something.
Sent on the fly
Vantastic
Penns Woods
Tampin anchors are for fastening to concrete. Drill a hole and drive the anchors
( your second pic) in with the driver (your first pic). Then bolt whatever down into the anchor.
Mohawk Dave
SoCal
And just how heavy duty can Tampin anchors be? Size depending of course....
Pedestal buffer or full blown mill?
toplessHO
central florida
lead anchors (also called caulkins) were made before the steel anchors for concrete and block.
They are not as strong as steel anchors but still have their place for lighter duty applications. I have a couple hollow wall set tools that allow you to set them in the void of concrete blocks,which work great.
They do not meet fire code as they will melt under high heat and cause the object to become unattached.
Strouty
Southern Maine
Interesting, I have boxes of lead anchors like those. Maybe I need to buy a set so I can actually install them.
