Please Vote On Which Pole Barn Setup You Think Is Best!
Which Pole Barn Layout Do You Think Is Best?
  • 50X50 With Front Load Doors
    Votes: 21 37.5%
  • 44X60 With Side Load Doors
    Votes: 35 62.5%
  • Total voters
    56
jserr68594
I have two different pole barn layouts that I am considering building. I own two lots on a river and have a need to store boats, cars and yard equipment.
I want to do either a 44X60 with side load doors or a 50X50 with doors in the front. I like the idea of the side load so that the doors face my residence, but it limits the driveway apron. The front load seems like it could be slightly more functional.
I have included aerial drawings of the two layouts as well as a overhead that shows both where I live as well as the cottage house that I rent out. The cottage lot is where I want to put the building at. I have also included an interior layout that is to scale with the items I need to store/be able to move into the barn.
Please vote for whatever setup you think is the best option! Thanks.
ndfastang
Cheyenne Wyoming
The 40x60 is my favorite idea but you are going to be putting boats and such in there that you won't have much of a turn approach to the doors with that layout unless you plan to drive into the leach field. If so, that's my bet as long as the field isn't soggy wet. What kind of wind and what direction does it come from there. I had to build based off the wind direction here because , well, we have lots of high wind that will blow out your back wall if directed straight into the doors.
Dave5863
Washington
44x60 side entrance is the best for storage but 30 feet is NOT enough swing room to back anything in. You will grow to hate it. Ask me how I know.
Pluribus
Skagit County, WA
50x50 based on those designs. As Dave5863 said, 30' is not enough, and I think you'd hate it on the first day and every day thereafter. You didn't mention what size boats, but backing a trailer into the shop and having to make a 90 degree turn in a 30' wide space would be miserable.
jollygreengiant
Ontario, Canada
I agree with all of the above. If your leach field wasn't there I'd consider the side door option but no way with it there. If you have side doors you WILL need to drive on the leach field area to get a boat into side doors. And unless your only going to be moving your trailer when the ground is dry you'll eventually end up making a mess of the leach field area. With the end door option it's just a straight shot back from the road. Get either solid doors or doors with windows up high if your concerned about people seeing in.
Kev442
Wi
Didn't vote as I'm not happy with either.
I would never get a permit for the 50 x 50 with all that concrete around here.
Being a floodplain lot, you may not either.
J
jserr68594
If I did the side load, I would plan on driving in the leach field if it isn't wet. Also, I do have a side by side UTV that could be used to back trailers in when the leach field is too wet to drive on with a truck. Wind is not an issue where I am.
I agree, backing trailers in and out will be a challenge if the ground is wet. That said, I will typically only be pulling trailers a couple times a year. I launch my boat and leave it docked for the season, so it may not be too bad to deal with. Now if I had to get it in and out of the barn every weekend, it would be a totally different story!
Permitting is not going to be an issue. As far as the flood plain is concerned, the area where the house and building are is 15' above high water level.
J
jserr68594
Here's a third option with the main doors on the rear of the building:
BD1
north side
I say narrower, 40x60 .
I Think the narrow will be less money because of truss length.
What about wall height ?? 12' would be the minimum height.
LXCam
Having owned a commercial building that had my warehouse access dictated by a 30ft wide path, I’m with the other guys. The only decent method of getting trailers in and out was with a forklift, but you got that covered. I also agree with PD about having the doors facing the street. I think option three is a winner and what I would do.
NUTTSGT
Northern Central Ohio
Since you have all your "paint" skills, is it viable to look outside the box ? Turn the bldg layout, try both, 45° to an angle.
J
jserr68594
I am thinking 14' sidewalls with 12' high doors.
I concur. Which one gives you the best natural light and weather protection?
The rear of the property is south-facing so doors on that side would let in a good amount of light when opened. Weather protection is not much of a concern.
I personally can't see turning the building at a 45 degree angle. It seems to me the only way that is possible is if the building is significantly reduced in size unless I am thinking incorrectly.
HAULNSS
MN
I vote for whichever is easiest to back trailers in and doors on the ends so that snow and rain don't fall in front of the doors.
Natural light doesn't concern me much as I don't have any windows in my buildings for security reasons and to keep prying eyes from seeing what is inside.
I'd also avoid any traffic near a septic system.
Good luck with the selection!
Randy
vavet
Ashland, VA
I like the side load. As for dealing with trailer backing. Do you have options other than a truck? A tractor? Or one of those battery operated tugs? That could make all the difference in that being a viable option.
