Pliers; How Many Is Too Many?
LesserSon
PA USA
Here are two pairs of unbranded slipjoints - one standard and one thin-nosed. Both have depressed diamonds grips without bracketing bars. Both have “DROP FORGED” on the inside flats near the pivot.
Barcalo?
EXTENSIVELY EDITED since first posted:
The nonbranded slipjoints I posted a few pages back have the same “DROP FORGED” as the Merit slipjoints, so now I don’t think Barcalo for them, but JP Danielson. Or rather, I don’t know what to think, because I have not seen that drop forged mark on Danielson pliers, which often have a date code there, but I have seen a similar drop forged mark on AA’s Barcalo battery pliers. AA says “A.0”and “LC”(via Lectrolite) are Sears manufacturer codes for Danielson, so I wonder about “A/C” - could it be Barcalo? Could Lauver’s list be wrong non-exhaustive, since it was Craftsman-focused, while this is Merit? Actually, I don’t see A/C or AC on the list at all. Maybe I’m looking at the wrong post?
The Merit linemen’s sure look like the example of Barcalo on AA. And really, so do the two unbranded slips, too.
LesserSon
PA USA
Lauver's list shows "AC" as being J.P. Danielson, and "BT" as Vlchek. Something rather odd about that Merit side-cutter.
I’m not seeing AC, much less seeing it attributed to Danielson.
What, specifically, is odd about the side-cutter? (Assuming you mean the slipjoints and not the linemens.) The pattern is not popular, but I have Craftsman, FSP, Bonney examples with recessed head screws, and Utica, Danielson examples with cap head screws that are pretty similar.
LesserSon
PA USA
I’m going to have to do some digging to find these Craftsman, to see what grip pattern they have. The profile of the head makes me think Utica, but the handles don’t.
I have just two pair Utica-branded.
EDIT - that turned out to be a lie; I have four pairs. Here are recently-exhumed pairs.
Bonney:
IMG_7793.jpegTop three are Bonney-branded Utica-mfd. Then two Bonney branded, Danielson-mfd, and a “UTEE-CO” Danielson-mfd at bottom.
The rest that I can lay hands on are all Forged Steel Products / VacuumGrip.
I think someone posted a pair of slip-joint diagonal cutters recently. I’ve picked them up to look at, but don’t see the practicality of them, or these. If I had to cut something thick enough to need the wider jaw position, I’d prefer a bigger tool with longer handles for the leverage.
They remain a mystery to me, but both of Danielson’s grip patterns are represented.
(If I collected Kraeuter) I would expect to find examples of sidecutter slipjoints, based on the illustration on the design patent (for grip pattern) I posted upthread.
USD59602.pdf
So not one, but two pairs of Craftsman sidecutter slipjoints, both with nested diamonds grip pattern. Finding them was tricky, but worthwhile, because I put away a wayward pair of same-era dikes that had been laying around.
Previously posted examples of sidecutter slipjoints.
(Could Lauver’s list be wrong?)
Well, yes, there always is that possibility. Unfortunately he hasn't been around for a while.
odd... it's on MY copy (attached)
When Lauver was still active, I was downloading that list every time I saw him to an update.
The notepad *.txt file has the most recent updates at the top - below you will find earlier versions.
I'm referring to the pair of "MERIT" pliers in the center of the photos in post #1603 - I was just remarking on it's somewhat odd design - kind of "slip joint meets European combination pliers" (Kombizangen - like Your Mansco model)
  • A1_Craftsman Hand Tool Manufacturers & Date Ranges.txt
I wonder what “Fuller’s” is, then?
I wonder too.
A-A explains the New York based FULLER tool company's association with Japanese makers and also their use of other off-shore manufacturers in their write up on the company.
I have seen other pliers marked FULLER'S, but have yet to figure out why they're marked that way.
I don’t know either but this Fuller’s screwdriver I found yesterday is definitely not offshore. IMG_7847.jpeg
LesserSon
PA USA
I picked up another mystery “Mc.D. \ U.S. \ A.” pliers today, because I think there’s a difference from the other pair.
Yes. On the new pair, both the stamps are the same, but on the old pair, one is different.
^ I see what you mean.
My bet, for the record, is still on these pliers being made by an outfit such as Harrold, and the "Mc.D" referring not to an OEM or retailer but an outfit such as A.Y. McDonald Mfg Co, who made pumps and valves, just for example.
Leviton
Oregon
Haven't seen any Heathkit mechanical hand tools posted on Garage Journal. I found a pair of 6" Heathkit-marked long nose pliers. They are stamped: "Heathkit Made In U.S.A.". (There are no markings on the back.)
The pliers are well made. I'm not positive who the manufacturer was, but there is a Klein manufactured side-cutter on ebay stamped both Klein and Heathkit. And in a 1961 Heathkit catalog they mentioned that the larger size toolkit (GH-10) had: “Midget Longnose Pliers with plastic-covered handles by Klein”. Mine are not midget size, but the catalog caption is another datapoint showing Klein did make made pliers for Heathkit.
I don't recall any, either. Their multimeters and other equipment are popular topics in this thread, though...
LesserSon
PA USA
R JENNING FORGED STEEL
I’ve spotted this a few times at flea market(s), and finally bought it today.
On eBay, I see five examples of “R. Jenning”, one probable “R. Jennings (top center), and one definite “R. Jennings” (below). Some are also stamped Germany, so maybe a New York importer or retail hardware shop.
cody1325
Southwest Virginia
After almost two years, my Harbor Freight finally had some of the Talon Grip clones on the shelf. Gotta admit, I like 'em.
However, I do wish they'd chosen to go with the smaller sizes; as these are pretty bulky compared to my other like what, ten pairs of needlenose?
And another, much smaller addition from Tractor Supply--Crescent flush cuts and mini needlenose pliers.
These cut filament and support material really well. The pliers are basically tweezers with a handle.
Here is another pair of "forged steel USA in a triangle" pliers. The triangle is a bit rounded on this one. Tips are not damaged other than a bit of rust. Still trying to decide if the first pivot has markings around the perimeter, or just rust marks, but pretty sure rust. Do I add these to the Harrold thread, or no?
cody1325
Southwest Virginia
This box-jointed Elliott-Lucas came home with me today. A bit over 5” (I suppose I should find my metric rule and measure it proper-like).
“GPO” and “1967”…hmm
General Post Office, I believe. At the time, under nationalization, they handled the telephone systems in Britain. So, of a British "Bell System" in a way.
LesserSon
PA USA
In my ongoing casual accumulation of other-branded Crescent checkerdot slipjoints, I picked up a pair of Stowe Supply KS MO model 30B. Stowe went through a few name changes, which may narrow production date. IMG_0269.jpeg
Early MoToR Kit CTCo shown in a scan of c1924 No30 Stowe Supply CO KS MO catalog. Plausibly, they reprinted manufacturers’ cuts, so their own name wasn’t on the illustration. Or they negotiated to have their name stamped on pliers at a later date.
A couple I got a week ot two back
"Snap lock" pliers by Seymore Smith & Son - I liked the blued finish and the swivel jaw:
And a pair of small H+M "StraightLine" 3 position slip joint small water pump pliers - these have the "steel cable" grip pattern? I need to do a comparison...
Seymore Smith & Son
I posted some patent and other info on a Seymour Heinie Smith thread here...
LesserSon
PA USA
These riveted Ford script slipjoints came home rusty, with chipping blue-painted handles. Now I’m wondering at the manufacturer. Rough but patternless grips, and small forge marks: B-in-an-oval, 11, and either a 12 or just a 2.
The B in an oval shows up on my Barcalo Auto wrench as well as a Ford script auto wrench. They are shown in the Model T thread.IMG_0559.png
IMG_0560.png-Don
Leviton
Oregon
Has anyone ever come across pliers with X4 or Z8 forge marks?
I found this pair of 6-inch slip-joint combination pliers and those were the only markings. Just looking for a clue about the manufacturer.
(The sides of the handles were plain - no grip patterns.)
Unbranded "these might come in handy one day" flea find, with smooth, small tube/pipette shaped jaws. Oddly enough, that "319B" model number shows up on GJ, but they are mystery Utica short chain-nose pliers that @LesserSon owns, nothing like this.
