Pliers to cut chain link fencing
Bruce Wayne
I was wondering what you folks would recommend to cut chain link fencing? Would Knipex 71 01 200 get the job done? Is there a less expensive option?
Thanx!
Charlie
DSLTRK
PHELAN, CA
Thanx!
Charlie
What gauge? 9? 11? 11.5?
Also, what purpose of fence? For security, I'd use lineman pliers, creates a sharp point at end of wire.
For residential, Just use any pair of fence pliers that shear the wire, instead of splitting it when cutting.
And the Knipex mini bolt cutters will cut 9 gauge chainlink like butter, will leave sharp point though.
kctyphoon
Jersey/Staten Island
The better question is how much or how long do you need to do this. You can get 12" bolt cutters from HF for $9 before any discount. I'd think the Knipex mini or XL mini bolt cutters would be a good option for this too, but at $50 a pair I wouldn't buy em just to do a small project.
My partner at work has some 12" or 16" cheap bolt cutters we got from HD or HF. I've used them to cut 6.6 strand we use to hang phone cables and anchor poles. It's the smallest sized strand we use, with a 6,000 lb breaking strength. They work just fine on that, so I can't imagine them not making cutting some fence a breeze. The longer the handles, the easier your cutting will be - but you don't need anything big for this. I'd spend the $9 and get the HF 12" bolt cutters.. they'd work well for this. I wouldn't bother "buying" diagonals or lineman pliers for this. It's not what they're made for, but if you insist - a pair of 10" Knipex diagonals would also work - just not as well..
gdocktor3
Connecticut
Well, Bruce Wayne, if you're a "superman" you can use side cutters, linesman pliers, fencing tool, small bolt cutters, etc. If you're in fact a little boy, get some 4' bolt cutters.
T45
How many cuts is the question...For a couple of cuts or for a couple of hundred/? In the latter case the finish of the cut, the tool ergos, and durability matter much more. In the former case, ad-hoc solutions might not be ruled out.
kctyphoon
Fencing pliers. They will cut it easily and be handy for other associated tasks.
https://www.amazon.com/gp/aw/d/B001BQ49YU
Sent from my XT1575 using Tapatalk
I think those are made more for large opening chicken wire type or single wire "farm type" fencing that gets stapled onto wooden posts. They might work great for all I know, but you might have a hard time trying to fit that head through the chain link to get to the cutters, since they don't cut from the tip of the tool. They are designed to replace someone having to carry cutters, pliers, and a hammer to staple thin wire fence up, and do repairs when you'd need to twist broken wires of a fence together. (Hence the staple holding feature).
I actually have 2 pairs of them, the channellock and Milwaukee (almost identical), and still haven't found a reason to use them yet.
Edit - learned something today.. if your installing, you can do no cutting at all...
Bruce Wayne
Thanks for the responses fellas. I should probably add that I need something a little more mobile than bolt cutters. Something that can fit in a small bag.
Thanx!
Charlie
CNGsaves
KS and OK
Since this . . . . IS . . . . GJ . . . the "best" tool for the job . .
. . is. . . . . Milwaukee 18v fuel cordless grinder with cutoff wheel !!!! ;)
. . . . OR . . .
. . . You could setup MacGyver contraption w/ 40v cordless edger w/ CUTOFF wheel !! :D . . :bounce:
firworks
IL
. . . . OR . . .
I used a long extension cord and a corded grinder when I took down my fence. I think it was just one of the HF 9$ jobbies. I started out killing myself using a pair of snips and after my hands fell off, I decided to try something else.
Teenager with old tools
riverside california
. . . . OR . . .
I think the best tool for the job would be buy the most expensive biggest 3 phase air compressor you can find with 100 feet of the most expensive hose. Buy a generator to power it. Buy the most espensive air grinder
Milton Shaw
The Cobbler is right just straighten the end and un-stitch the fence. That's why they call it chainlink, just one link needs to be removed to cut the fence in two parts.
Packard V8
Spokane, WA
Every spy movie/TV series, they pull out the cutters, have a circular hole in about nineteen seconds; but when they're coming back out with the goodies, they always get caught. How are you at kung fu fighting?
Of course, Q always gives Bond, James Bond, a watch with a laser which will do the same thing, just faster and quieter.
After all, it's a holiday, so we shouldn't be thinking too hard about work ;>)
jack vines
scissorman
Pleasanton, Ca.
Fencing pliers work perfect. They are a very handy tool for many purposes.
KRB52
Strong acid, C-4, Bangalore torpedo. Might as well make it fun. Just what kind of a facility are you trying to break into, anyway?
lakeroadster
Central Colorado
Thanx!
Charlie
Mobile.... :lol_hitti
See if your alter ego will let you borrow his utility belt.... That laser torch will work great!
Seriously... you're punking us, right?
kctyphoon
Thanx!
Charlie
Just to point out - you're only gonna get out of this, what you put into it.. not one person that's responded so far knows what you need, want, or plan to do.. knowing if you need to just cut a hole in a fence, or remove 20,000 linear feat of chain link might help people give you better answers.. knowing you have to hike 6 hours into the woods, or if the fence is sitting outside your front door might also help.. there's probably a dozen or more things that will work fine, some will just be a little easier, some will be more expensive to buy.
If you're trying to break into Area 51 id probably still say the knipex mini bolt cutters are a good choice, and compact enough for your getaway, but might be more than you wanna spend on a disposable tool you're going to dump after cutting the last fence. In that case the $9 HF 12" bolt cutters might give you some more leverage for faster cutting and you wont cry over dumping it either.
R.Anderson
Wisconsin
'What are the best zipties for restraining large security goons?'
These right here:
http://www.handcuffwarehouse.com/Cobra-Cuffs.html?pid=3897&gclid=CM6i6e_awtACFRc8gQodLDEC6g
This thread will be followed by "how do you cut a hole in glass", And then "how do you pick a lock"..
Leave the cutting a hole through glass that is for movies, find ya self another route.
Pends on the lock. For standard pin tumbler locks with picks, practice practice practice.
:D
I third those 12" bolt cutters from HF even Menards sells a similar pair.
I kinda question if this is for illegal activity, but doubt it is.
Roberts210
Missouri
I like Channellock a lot. I have used their 12" end cutters for many years. Besides cutting wires and small bolts they are also great for pulling out nails.
Joe Mamma
Thanx!
Charlie
You may want to consider the Wiha BiCut diagonal cutters. I have not used them yet. But maybe someone else here has and can offer comments.
It looks like a small two stage compound leverage diagonal cutter. You push a button for the high leverage position.
http://toolguyd.com/wiha-bicut-cutters/
Joe Mamma
jshillin
PA
I have those small Knipex Bolt Cutters and they work really well. I've used them to cut a variety of things and they just keep impressing me.
jhelrey
MN
I install fences professionally. I use fencing pliers. On the heavier gauges, mini bolt cutters.
2oolhound
BC Canada
I had to cut through some once and happened to have some 10" klein lineman pliers with me. I was surprised how easily they cut through. The pliers were in good condition though, just make sure the cutter isn't wore out.
oldldh
Fairhope, AL
To bring this back on topic...
Tekton sells some 11" diagonal cutters...for $14.99...
And...
Some 8" mini bolt cutters...for $7.71...
Both available from Amazon...
I have both of them, and they work as advertised...
FullRaceMerc
SoCal (SGV)
Thanx!
Charlie
I use a small set of bolt cutters. They're probably 12". Too small for cutting the average bolt, but a good size for fence materials. They would fit in a fairly small tool bag. Normally I use them to cut closet bolts (Toilet mounting bolts), but they come out for fence work too.
ishiboo
Oshkosh, WI
Knipex bolt cutters with notch.
As mentioned though with chain link, you're not really doing a lot of cutting if any.
I cut a lot of 12.5ga high tensile, which is probably harder than most chain link fabric... but fencing pliers, diagonal cutters (even compound), etc. all kill your hand pretty quick. The Knipex's work great especially with the notch, the only way to really improve would be to have them spring-loaded.
I have a set of the Tekton mini bolt cutters as well and they're not great for fence wire at all.
