Smokeshow69
I found this packard at8067 wrench in the big estate buy out I did last weekend. Is this Bonney made? Part of a large gmtk😂👍
Smokeshow69
Part of Snapmom’s
Packard Built Rolls Royce Merlin Tool Kit AT9368​
check out the first picture in her thread.
I checked that thread and posted this wrench over there as well. I asked the same question and no one has said who made it?? Someone did offer me $13.50 for it but I really have no clue what it’s worth ? Can’t find any on ebay
Snapmom would probably have the best idea. I’m pretty sure I know who made this one that Tin Medic sent me recently. One of these is shown in that toolset too.
-DonF6B1293B-EB86-4EC2-B2CA-2C6B75D2607B.jpeg864CF14F-4FED-4E76-B0C4-5757966253FC.jpeg
Smokeshow69
Yup, that’s who offered me… and interesting what pops up on eBay sold listings😉. I would totally be up for trading someone some plomb or Proto?
I agree with RJ. I have listed tools on eBay that I expected to get $20.00 for and they were bid up way higher than I expected. It only happens occasionally. Snapmom has sent me tools at no cost that I had been unable to find after searching for quite a while. Her minimum bid amount on the wrench she sold was only $29.50. She was probably surprised that it was bid up so high!
I had occasion to look through my non-chrome Plomb combos today. I seem to have some extra 5/8” wrenches.
Here are my Plomb estate sale finds from today after cleaning 4024D41A-64CB-4851-8BC7-4693C39C566C.jpeg
This will replace the prewar one in my Plomb based GMTK when it comes out of the evaporust C183C343-F5BC-4979-9348-B4E6E476B56F.jpeg
MR.X
I've seen quite a few of that particular wrench and they all had Bonney date codes. That wrench looks very much like a Bonney by shape and marking. Many of the ones I've seen were marked with the CV in a circle and Chrome-Vanadium but not having a CV marking would not be evidence by itself of course. Look to see if there's any evidence of the date codes right by the drilled hole in yours. Also, yours has the decimal equiv. 1.101 of 5/8 whitworth but that doesn't match the 1 1/4" marking stamped on the opposite side does it? Wouldn't that be 1.25?
LesserSon
PA USA
What, if anything, is the significance of the subscript “F” following the model number?
Smokeshow69
I checked around the drilled holes and no dates around there. In terms of the decimal equivalent, you are right- it should be 1.25, not the 1.101. That’s really odd!
MR.X
Right, but the 1.101 would be correct if it is in fact a 5/8 whitworth. I'm assuming the 1 1/4 is the incorrect mark...did you measure the distance across the flats?
Smokeshow69
I have measured it both with a ruler and comparing it to an actual 1-1/4 wrench and it truly is 1-1/4.
Farmer J.
UK, Cornwall/Hertfordshire.
I haven't been following this debate and couldn't find the original post , but a wrench for original Whitworth size of 5/8" is correct at 1 1/4" (1.25") measured across the flats. The British Standard Whitworth sizes moved everything down one size step from the original Whitworth standard.
What's the problem?
MR.X
What's the problem?
Well, it's not a debate, it's 2 guys talking about a wrench. The issue is the size markings from the pictures on post 12,246 of this thread. On one side it's marked 1 1/4 on the other 1.101. Here's another AT8067 marked 1.101 and 5/8 but you'll see it's not 1 1/4", it's just under 1 1/8" which would match the 1.101. Smokeshow69 says his 5/8 whitworth, with the same AT8067 tool number and 1.101 marking is 1 1/4. do you see the problem now?
MR.X
Here's a larger wrench from the Merlin Packard toolkit. It's an 11/16 Whitworth marked 1.201 and it's just shy of 1 1/4" which one would expect from the decimal marking.
MR.X
Also, the spanner jaw size link you included....looking down the "spanner British" column at "W" marked fractional sizes and then scanning across the line to the corresponding jaw sizes expressed in decimal format and they match all the "whitworth" sized Merlin Packard wrench samples that I have in front of me at this location, so the wrenches that we are talking about appear to be using whatever that format is for sizing.
Farmer J.
Thank you, yes I see the problem now. Now we have 3 guys talking about a wrench, and hopefully as the 3rd one wading in I have a solution for the problem of the previous 2. Here is what I believe is the answer, and the chaps in the workshop at Shuttleworth ( I went to college there) have already told me the same answer when I had the same problem:
One spanner is slightly older than the other, and the markings are made to a different standard.
During the Second World War the standards were changed as "War Emergency B.S. 916 : 1940" as an austerity measure to reduce steel consumption and this resulted in the normal BSW head sizes being reduced by one step, basically making the BSW = BSWS = BSF head size. If you stroll up to near the top of Mr Crawfords web page, above his size table, he gives a full story and explanation of it.
web pages for reference:
and
Farmer J.
That's good. You have a tool kit wherein all of the tools are marked to the same British Standard specification.
This is not always the case, beware,!
If they get muddled up with other tools marked differently they will still fit just as well but can cause confusion and amusement, resulting in prolonged discussion at tea breaks, and eventually the despair leads to 'going down the Pub'..:beer:
MR.X
During the Second World War the standards were changed as "War Emergency B.S. 916 : 1940" as an austerity measure to reduce steel consumption and this resulted in the normal BSW head sizes being reduced by one step, basically making the BSW = BSWS = BSF head size. If you stroll up to near the top of Mr Crawfords web page, above his size table, he gives a full story and explanation.
Do you have a link for pre "War emergency B.S. 916: 1940" whitworth sizes chart? i read Mr Crawford's explanation when you sent it initially but couldn't seem to match up any of the standards with 1 1/4" AF.....but assuming that that's just my comprehension problem there's still the initial issue of a wrench (spanner) marked 1 1/4" that does actually measure 1 1/4" across the flats but is ALSO marked with a size expressed in decimal format (1.101) that would imply the opening is between 1 1/16 and 1 1/8"....so it's not marked to a different standard it appears to be mismarked. Of course confusion over the changing standard could be the reason for the marking discrepancy. I suppose it could be a case of professionally widening the jaws and stamping the new size without addressing the already present markings too but that seems unlikely. So again, I understand the concept of 2 Whitworth wrenches having the exact same size marking but having different sized jaw openings depending on what standard they were using when they were manufactured. The U.S. had a similar thing in the late 20's and people who find old wrenches are always thinking they found an error or mistake. This wrench has the additional element of the decimal sizing.
Farmer J.
Ah, I see the problem but have no immediate explanation for this. Having thought about it for a while I am now at the limit of my mental capacity!
I don't have a pre B S 916 : 1940 size chart, but will make some enquiries and attempt to seek out.
Thank you for your patience, I thought I had a simple answer and could help with this one.:confused:
What do the working surfaces of the jaws look like - It's possible it was mis-marked during war time transition, but also it could have been modified (but that doesn't tie in with one marking being correct)
MR.X
I appreciate it. You inspired me to pull out those wrenches and check to see if I was talking out my A-- or what and to relook what I thought I knew about Whitworth et al.sizing conventions. That bit about the change in 1940 seems like it would be a perfect storm of chaos for not just the tool makers but I can't imagine what the guys at Packard were going through.
Smokeshow69
The jaws look factory and not modified or broached to accommodate a new size. I have a few plomb wrenches that were factory broached to the correct size and you can see the modifications. No such signs here.
Smokeshow69
Picture of said wrench opening showing 1.25”… also showing no signs of modification after initial forging
It was just posted yesterday, I was lucky to run across it shortly after it went up. When I got it this morning the guy said there were a bunch of people in line behind me.
I’ll take better pics if the sun ever comes out!
Looks like you got your $100.00 box for half the going rate! Plus no shipping.
