Mintgrun
Kingston, Wa.
I bought this 2336 gasket scraper yesterday and cleaned it up a bit. It's had a rough life, but probably got a lot of work done, based on how short the tip of the blade is and the overall condition. Date code says 0D, so I'm thinking it was produced in April of 1940. Searching "gasket scraper" pulled up some nice examples in this thread, but apparently nobody included the 2336 part number.
I wrapped the skinny end of the wood handle with electrical tape and hung the business end in the electrolysis bucket, with the water line at the tape and let it fizz for an hour or so, before scrubbing with a wire brush. I sure do like that bucket.
Straightening it was fun. It was surprisingly malleable. I clamped the shank in a vise and flossed the wood with a strip of rag to remove some of the greasy dirt and polish it up a bit. The flash made the steel parts look shiner than in real life. It's funny, part of me regrets scrubbing the brown off of the steel. I don't regret straightening it though.
Tom
Smokeshow69
Tom
Nice job! It’s had a rough life but it’s in better shape than when you found it and not a super common find since most were used up over time.
Lesserstore
Texas
I picked this up for a $1.25 at my local pawn shop. I couldn't see any markings, but it looked like a plomb so I bought it. It was a plain steel finish with some rust on the crank area so I put it in evaporust. Today I took it out and still couldn't see any markings, until I saw what looked like a faint "P" on the area circled. But the only Plomb speeders I find have it on the long section. Do I have a Plomb or something else?
MisterEd
Florida
WF-7 Hinge Handle/Breaker Bar, WF-9 Sliding Bar Handle and WF-10 3/16” (6 point), WF-11 (6 point) 1/4” & WF-13 11/32 (12 point) Sockets
RubiconJK
"I'm bad, I'm Nationwide"
Am I misinterpreting RJK’s note, 8-1/2”? This one is 7”, looks like factory end to me.
As noted in the post I made which you are referring to, I was sharing a copy of a list of Ranger AT marked Plomb tools which GJ member Plombob put together on his great old website (now archived). The link to his list in my original post does still work if you'd like to see it there. Your 7" ratchet does indeed look factory, so perhaps the 8 1/2" example noted as "odd style" in the list was a unique example of that piece?
Mintgrun
Kingston, Wa.
I found this little 9652 stubby today. It's pretty hefty, for a stubby. Total length is 4". (it's the first 9652 in this thread, according to the search function... we don't always type out the numbers though).
Prime candidate to be put into a Proto wood handle to make a killer wood handled spinner!
That's a fun idea. Make a faux dual marked spinner. I don't really have any good handle candidates though. The little one beside the spinner has had the tip ground off, but it'd have to have the ferrule drilled out larger.
To be honest, I sort of like the melted handle as is. I wonder if it survived a shop fire, or something.
Tom
Tom
Here is the one in my Plomb based GMTK. I hadn’t posted it individually before. It came from Roy Olson.
I finally made some progress on my Plomb based GMTK. This Utica made 12” adjustable and stubby screwdriver arrived from Roy yesterday.
Today I found a pair of water pump pliers at a garage sale that I like better for the 41-P-2100.99B099C6-7B98-4BF9-A717-177C214A7334.jpeg76AE73D2-4C29-4350-B430-6F08B9472C3A.jpegCA26F2A6-49E9-4336-944A-5C8DFE137657.jpeg
Here is the new 12” adjustable next to it’s Utica cousin,1DC33EF4-CAD9-4041-825D-E4D33409FC0F.jpeg77D5185E-BD43-42C0-BBE7-1B4CD2B959F8.jpeg
I showed it in this post 4/2/22 but didn’t list it individually.
I found this little 9652 stubby today...[ ]...Total length is 4"
Nice find. Catalogs listed it as 3-7/8", but, close enough, and close enough for the WWII era gov't spec (4") for a close-quarter screwdriver with tolerances (+/- 1/4").
Interesting you should say that. The No. 9651 is much stubbier. So much stubbier that when I found one I questioned, here, and here, why Plomb would make a close-quarter that did not meet the Gov't spec., i.e., why produce themselves out of a huge market? I believe the No. 9652 is the answer.
Ed in Virginia
Montpelier, VA
I only have one Plomb tool. I bought it to use on Ford flathead engines to compress valve springs to remove the valve keepers.
  • Plomb Valve Spring Compression Tool - close-up of mfg name and part number.png
Smokeshow69
Tom
I just found a spare last month but didnt list it individually when I posted picutures of my finds. I need to get better about doing that.
RagTopTA
Wichita Falls , Texas
Tom
Its neat either way! I have a few ideas and some I have seen on here of other Plomb tools I wanna make with proto wooden handles. Also I have another smaller Plomb hammer proto type in the works!
Spokane
Spokane, WA
Plomb (and misc) $25 garage sale find. Not sure how to post all of this...
Spokane
Spokane, WA
Spokane
Spokane, WA
Spokane
Spokane, WA
Spokane
Spokane, WA
Spokane
Spokane, WA
Old Radar
San Antonio, TX
Welcome, Spokane! Looks like you got yourself a ****-worthy haul for $25!
Garage Journal has an annual Garage Sale thread and 2022's is linked here.
We'd be happy to welcome you and your finds there. You'll be among a throng of fellow Garage Sale, Estate Sale, Flea Market, Facebook and Craigslist enthusiasts that love to display their finds and bask in the accolades of appreciative viewers.
Read the "guidelines" in the first post and feel free to post away!
Mintgrun
Kingston, Wa.
I picked up this 5449 1/2" ratchet yesterday for $2.
I suspect it was priced cheap because the selector lever (is thin and it) was bent down and stuck in the hole in the middle, so it didn't spin. (Plus it was caked with dried grease inside).
Wait... a hole? What's that doing there?? (It's just over 3/8" in diameter).
The removable drive plug was also a surprise.
I believe the 0D date code suggests 1930.
The ON / OFF script seems somewhat unique, based on Google image search. That big hole is nicely centered, as if it came that way, but I'm guessing it was user added... for some unknown reason. The lever has a tendency to move while using it. Maybe the hole had a spring and large BB to help with that. (?)
Tom
EDIT-- Ah ha! Post 5,566 by RagTopTA shed light on the hole. Time to find a BB and spring.
genog
Silicon Valley
Ole Picker McFlipper is my Go-To source for Plomb
I asked him to save them and put them aside, and he came up with another big plomb DBE for me
Mintgrun
Kingston, Wa.
A ball can be substituted for the original detent because the originals are quite hard to find.
Thank you for sharing those photos, Don. Is that detent on yours a spring loaded little ball, or just a bump that the lever has to climb over. It doesn't look like a BB. I might make an insert on the lathe, for the fun of it. I'll post some photos if I do, of course. :)
Tom
Provincial
Near Salem, OR
Looks like an easy lathe project. Perhaps someone can verify that the plunger is counterbored to contain the spring. That way, the plunger can be longer to keep it in alignment. Overall length determined as just short enough for the lever to slide over the top of the bump when the plunger is bottomed out. The projection of the plunger tip should be about half the thickness of the lever, and beveled at a shallow enough angle to let the lever push the plunger down, but not accidentally.
Tom
I was first made aware of the detent device when I finally noticed that the detent was missing on the 1939 marked ratchet that came in my Challenger set.
I searched for a 1939 or 1940 3/8” drive ratchet with the detent and purchased the 1940 1/2” drive ratchet pictured above, hoping that the detent piece would interchange between the two drive sizes. Unfortunately, the detent on the 1/2” drive ratchet was slightly larger than the one missing from my 3/8” drive ratchet. Eventually in 2019 Catfish Dan came to my rescue, sending me a 3/8” drive ratchet with the piece in place to donate to my otherwise pristine ratchet. I wish that I had taken pictures of the detent and spring when I did the exchange.
D20A5EC2-B782-4120-93D1-9C327CA59225.jpeg04BB7A28-048E-4D52-9A74-3A718C4176B5.jpeg868C90D8-AB0F-45E4-8CCC-D0769D757D7F.jpeg6ED13112-A344-4A3E-8D33-B8D9D58B850E.jpeg
Mintgrun
Kingston, Wa.
I found this in the kitchen utensils bin at the St Vincent DePaul store today. I guess it's a meat fork. :D
The fork was too rusty to see the maker's mark, so I pulled it out and hung it in the E-bucket. This might be the first round-O tool I've found. There is still some chrome left on the tang.
The person who puts price tags on at that store has a very BAD habit of putting two inch wide Mylar tape over the little sticker and it pulled the paint off of the handle. I guess they're afraid someone will remove the $3 tag and try to get a better price, or something.
The photos of weed picks earlier in the thread show how the ferrule was made. That'll be a fun bit to replace.
AK4570
Western Montana
I picked a Plvmb 4766 last year to which a PO had welded a length of allen wrench for some long forgotten task.20220716_123341.jpg
It languished in my "someday" pile until catching my eye with its woebegone destitution (...working as much vocabulary into this post as humanly possible...)
A quick nip with a cut-off wheel in the Dremel restored it to its naturally short state...
I cleaned up the sides of the tab with a file... and it's back in business!
bmwrd0
Beaver Fever Oregon
Years ago, I picked up a Proto Professional 3/4" breaker bar that someone had welded something to the flex end on. I don't know why bought it, but I did spend several hours getting that thing back in shape, as it has some seriously hardened steel!
Smokeshow69
Nice find! Don’t see to many of those around and most folks forget they made them.
Sometimes those small saves or repairs to items that require more effort than they are worth monetarily are the most satisfying! Looks great!
