Plu.b tool identification
labrat12
Anyone have ever seen a handle like this, what is its purpose. This is a plumb 5449
Looks like it might be one of the types of cranks they made and sold special to a few industries and customers, leveraging/modifying their standard ratchets. In this case the 5449 1/2-inch drive. Missing the rotating knob. I don't have one to verify, but if you search the Plomb thread you'll see several examples.
Do you have a photo of the part number/cover plate? I’m curious if there are any additional markings. It does appear to be a shortened version if it’s a 5449.
I’ve never seen that piece for the end, even if it had a knob type handle as Lugz mentioned.
If not a knob than a grip handle that slips right over that pin, 3bay. Maybe the aircraft crank. Someone had one. Can't remember who. EDIT: It was you! Haha. And Roob. Couple others. I defer to you. Just looks naturally crank-y to me.
Yes, that might have been me. I have a good assortment of crank ratchets. The part on the end of this ratchet looks almost like a fitting. Too hard to tell from the photo if that’s a tube or a tapped hole or what. If it is a tapped hole, it doesn’t match with any type of knob I’ve seen on Plomb/Proto.
L
labrat12
Ok, crank handle makes sense. The hole in the tube is threaded. Thank you guys
Yes. The winch is a Williams. Snap-On was landing gear, Plomb/Proto Bell System cable tool.
Thank you for confirming the hole is threaded Labrat. I think Lugz is onto something. This looks similar to the wood knob ratchets.
That's the idea. Missing the knob and the screw. Granted, the right angle connection to the ratchet is different. I think we need to consider the possibility this is a homemade one-off. Wouldn't be too hard for a shop to get that fitting on the end.
