burleyfarm
Need help. I know it’s not a garage but the garage is attached. [emoji4]. Hope someone can help. I’d like to be able to install a small laundry sink in the basement utility room. Instead of cutting the floor and installing an additional drain I’d like to first investigate if it’s possible to use this drain. I would need each of these drain tubes to still be functional at the same elevation. They are furnace, dehumidifier, water heater and water softner salt tank overflows. The drain is connected to the basement sewer pump that pumps the basement bathroom and utility rooms up to the septic tank. Any thoughts?
No, just stating what the code says.
