Plumbing for air, input wanted.
matt_i
I like to back each female quick connect on a trunk line with a ball valve that has threads (iow not sweat-soldered). If I can find them I will buy Nibco. The quick connectors have an irritating ability to leak after awhile which as you will eventually find is an expensive leak. Compressing air is not cheap.
bkvanbek
What is the right size hose and fitting, 1/4", or 3/8" or 1/2"? As previously posted my smallest line is 1/2".
bkvanbek
filter and regulator and or lubricator?
I put a cheap 3 in 1, after a couple months of light use it leaks, garbage. Since I plumbed big, should I get a 3/4"? Should I get a lubricator? Often I just need to air up tires or blow off something?
What brand to get, good value? Ingersoll Rand? Pneumatic Plus? SMC?
Parker and ARO are expensive.
sberry
Brethren, Michigan
The reason the couplers all leak is the are usually installed wrong and used where there should be a screwed connection. If a guy has reels and a drop or 2 in the right location the only need for a coupler is at the working tool end.
bkvanbek
I should have been more clear. I need to know what to get for a filter regulator. The cheapy I bought leaks at a bowl and I am returning it.
What brand to get, good value? Ingersoll Rand? Pneumatic Plus? SMC? ARO?
Parker are expensive.
manwithtools
Lebanon, TN
I would not put a FRL (Filter/Regulator/Lubricator) or 3 in 1 as you called it between the compressor and your main air line. A filter is okay there, but only put a lubricator at the drops where you will be using air tools. Even then I don't care for them, I'd rather add air tool oil directly to the tools. Inevitably the Lubricator unit is under oiling or over oiling or out of oil all together.
Having a regulator at each drop allows setting the working pressure to the optimum for the job at had with out affecting other drops.
You really want to keep the supply lines free from oil. If you ever want to paint anything, oil in the lines will be your enemy.
As for brands, I'll vote for SMC and Parker. Try eBay for good deals on them, look for industrial surplus offerings. Get a 3/4" if you can find one at a reasonable price.
By the way, by using the 3/4" copper instead of the 1/2" you effectively added 10 extra gallons of air storage to your system - I like that extra reserve of air as it can reduce the on/off cycling of the compressor.
akdiesel
Wasilla, AK
This exactly
Norcal
If you put a lubricator in the main line the entire line is contaminated with oil, painting and bead blasting do not do well with oil in the lines. Post # 48 says it well.
TAMPAGT07
Palm Harbor, Fl
I just did 1/2" L copper in my garage.. It's only 900 sq ft, and I only ran 50" of copper.. I have only three drops and it works fine for me so far...
bkvanbek
I just got a new 1" Parker P3NE on eBay for $100, they are usually more than $300. I will oil the tools individually.
