My compressor is what started life as a Speedaire 60 gallon 5hp. I bought it for $50 with a blown up pump. I put a harbor freight 5hp twin cylinder pump on it. It worked ok for awhile, then blew a reed valve. But that's since been repaired.
If you care to watch, here's a link to my 6 part videos of repairing the Harbor Freight compressor pump.
I used this compressor to sand blast my 72 Yamaha XS2 frame. I used the plastic HF gravity fed sand blaster. Lots of issues with clogging and moisture. I was basically washing the frame off with water as I went along,,,lol.
Lesson learned. Improperly plumbed from the start. Can't blame the equipment.
So now I'm setting up a HF sand blast cabinet. I've done most of the mods except swapping out the gun. I definitely need to re-plumb this thing.
I have a very small garage so the cabinet is only 8' from the compressor. In the HF owners manual it shows a very basic plumbing set up. But it says to use 3/4'' pipe for the main line, and then 1/2'' for the drop. Since I'm so close could I just use 1/2'' for the main or would I be better off with the 3/4''. Or is this HF idea just not worth doing?
I would love to do one of the big up and down thingy's with the copper, but that's not in the budget right now.
My main problem is moisture. I would love to put an after cooler on the compressor. But the HF pump has some weird 3/4'' refrigeration line on it. I had a very hard time finding the right fitting to hook it up. So I think if I tried to use some kind of transmission cooler on it with 1/2'' or smaller fittings it would create a huge bottle neck. Right? I don't know if I could even find the right fitting to down size.
I've seen guys using a car a/c condenser also. I have a F250 condenser I would love to use but don't think I can because of the small line size. Right?
I should mention that I do want to do soda blasting with this cabinet too. All the aluminum stuff on both my motorcycle projects. Carbs, and side covers, ect. I'm doing a 72 Yamaha XS2 650, and a 72 Honda mini Z50. I'm thinking I'm going to need a lot better moisture control for soda. Or will I. But I just need yo get SOMETHING started,,,lol.
Here's the HF idea. Should I try it? I should mention I'm on a very tight budget. Heck. After doing all the mods to the cabinet (metering valve, lights, ect.) I'm kinda broke for awhile. It's hell being poor and on a fixed income,,,lol.
