Question: In the photo, there is a reduction in the pipe size from 1-1/4" to 1" then back to 1-1/4". Doe's this perform a function such as increasing pressure? Closer to the house, where the "House In" line goes, it reduces in size again. Anyways, what's more important, pressure or volume? Should I leave it or return it all to 1-1/4"?
Ok, the full story. Prior to moving in, the land was partitioned, with the old well located on the other property. A portion of the old line is still on my property and has a "T" going down to the garage and other areas. Since the line was cut off from the new well and the old well, there hasn't been any water available in those areas- garage etc. I've capped the other end of the line- the old line in. I'm going to reconnect to the new source and add a valve to control the garage etc. Plus I'm going to install another Tee and valve and cap that for future use. ie. spigot or irrigation. Thanks for your help and hope I spelled this out ok.- Doug
