Pocket prybars
Snapped-off
Indiana
I use my screwdriver to align the laces when a new joint is being put together. I really over use it when taking an old lace apart. A lot of times I have to remove a lace from the belt that’s damaged. Tell how the slip joint needle nose are so useful? I’m working on laces belting several times a week.
Pulling old pins out as well as feeding new pins into existing lacing. Sometimes we gotta feed like ⅛" at a time. We recently got some new pin in with a leader on it, but haven't tried it out yet.
wafrederick
Holton,Mi
I love CP’s videos. Such a disheveled mess sometimes….which normalizes everything.
Watching this video on the pocket pry bars and seeing just so many he has if this one type of tool…I’m always asking myself, where TF does he keep all his tools? He seems to have 7 or 8 of everything (ratchets withstanding…he probably has nearly 100 ratchets).
He is supposed to be getting a new toolbox as well
BarrelRoll
Alaska
I find that I don't use these often...unless i actually put them in my pocket. I use my SO picks constantly...
I agree with this. At home I don't even have one. At work I keep it in my pocket and use it all the time. I have a curved that hasn't left my tool box since I bought it. The straight in my pocket gets used hard
The guy has 8 million tools. I'm not sure if he actually turns wrenches for a living or just collects tools. The amount of tools he has is crazy. While it's nice to have options there's a point where too many options are not a good thing, just like too many shoes in your wife's closet...
Madjik Man
He does turn wrenches for a living.
But there’s no way he uses even a fraction of his tools. But his YouTube business is good business. So the more hauls and tool reviews he does, the better off his business is.
So I don’t blame him for always buying new tools.
In fact I love his vids.
That said, I’d have a hard time keeping track of what I have let alone ending up using it if I had that many tools.
Odd-job
Farmall450
Marengo, Illinois
Lang is in the game now too. Those look closer to the Snap On than anything else i've seen. 3/16" shank. Bent tip looks a bit more...well bent. I've been waiting on my Snap On ones for almost a year. Delay keeps getting pushed. I bought off the website though, so I'm thinking they have to service dealers first and I'll be in prybar purgatory forever lol
These look nice. I'm never disappointed by Lang/Kastar.
Tools4Me
Looks like Lisle jumped on the pocket pry bar wagon.
I don't care for the shiny slick plastic handles. I'd rather see some texture or graining like the MAC handles. Amazon shows these as being made in China. However, I do like that Lisle offers a 3/16 & 1/8 inch flat bar stock blade and that they didn't try to reimagine a regular pocket screwdriver.
I was thinking of ordering a set of those Lisle mini prybars, because I like how both bars are bent tipped and they have different square shaft sizes. I wanted to verify COO first, because I try to avoid anything that sends money to China as much as I can. Amazon does say they are made in China, but they are wrong about their COO's quite often in my exerience, so I emailed Lisle using the "Questions" link on their website. I was hoping they were going to tell me USA or Taiwan, but they just got back to me and said the COO is in fact China. I guess I will be passing on them.
I might end up buying a Mayhew, Lang, or Snap-on bent tip bar in the future, but for now I figured I would make myself a couple quick prototypes to see how useful I find them to be. I also want to figure out what tip shape or tip angle might be ideal for my uses before going through the effort of making "official" pry bars that are properly heat treated. I took a couple spare pocket screwdrivers I had laying around and heated up the last 1" or so with a propane torch until it was soft enough to bend without snapping. I clamped the base of each shaft into a small bench vise during that process, so the heat wouldn't travel down the shafts and damage the plastic handles. Then I bent the angles I wanted to try and smoothed out the profiles a bit using small metal files and some sandpaper. If I find heat treating necessary for strength, I will remove the handles and heat treat the shafts in the future. I'm expecting it will be necessary on the thin black handled one, but it might not be needed on the two thicker bars.
BarrelRoll
Alaska
I finally did some damage after 5 months of life in a mine giving it no mercy. The pocket clip is sprung and the shank has sunk into the handle after using it as a striking pry bar trying to get a key out of a key way. Time to drop it off at my snapon guy for another and use the spare next to it while it's in for warranty.
logical
Northern fringe of the Motor City Suburbs
I might end up buying a Mayhew, Lang, or Snap-on bent tip bar in the future, but for now I figured I would make myself a couple quick prototypes to see how useful I find them to be. I also want to figure out what tip shape or tip angle might be ideal for my uses before going through the effort of making "official" pry bars that are properly heat treated. I took a couple spare pocket screwdrivers I had laying around and heated up the last 1" or so with a propane torch until it was soft enough to bend without snapping. I clamped the base of each shaft into a small bench vise during that process, so the heat wouldn't travel down the shafts and damage the plastic handles. Then I bent the angles I wanted to try and smoothed out the profiles a bit using small metal files and some sandpaper. If I find heat treating necessary for strength, I will remove the handles and heat treat the shafts in the future. I'm expecting it will be necessary on the thin black handled one, but it might not be needed on the two thicker bars.DIY pry bars 1.JPG
I think I have that same junk screwdriver. I use it to poke open or unclog caulk tubes. 20230121_150849.jpg20230121_150843.jpg
Odd-job
Missed this post and bought the Lisle's assuming they were domestically produced. Can confirm they are made in China. Considered returning them, but am finding differing pocket pry bar options can get into different places and be more effective in prying various things.
Lisles - have angled tips for both, but different widths. Of my three pocket pry bar sets, these are in the middle in terms of thickness. One has a nice magnet to find orphaned 10mm sockets.
Langs are a good buy at only $5 more with a straight and an angle tip that are more versatile as a set, however find they are little bulky for delicate prying. While bulky they are the most durable and less likely to bend. The handles are also nice and bright when they get lost in dark places. The pocket clips are a little flimsy though. Already tweaked one.
Matco - nice and thin angled tip could get in places the other can't. These have the thinnest bars and are the most delicate. Pocket screwdriver has a nice magnet on the end like the Lisles.
Group shot
Ok I'm done buying pocket pry bars for now...
thr3squared
CA
I picked up a set of the Lisle ones on Amazon. Must have read the description fast because I didn’t realize they were different sizes which is nice.
They seem well made, time will tell. Only criticism I would initially have is that I wish the pocket clip sat a little more proud so you could clip it to a pants pocket if needed.
Plastikosmd
I’m not sure how you sit with some of these things in your pocket?
Maybe in overalls or monkey suit or carhart type pants with the side/leg pocket(s) I guess?
AJHD
shirt pocket, next to your pen/marker.
Yep. Never kept them in my pants pocket. As a mechanic we always had shirts with a pocket and at CAT we had coveralls.
On the topic, I've never had any issues with a pocket pry bar or screwdriver or anything else stabbing me in the chest. Even wearing a fall harness, it never caused a problem for me.
KnurledNut
n/a
I posted about the newly released Mayhew heavy duty pocket prybars in the New Tool Arrivals thread, but wanted to drop a mention here too.
More info and pics here:
https://www.garagejournal.com/forum/threads/show-your-new-tool-arrivals.103272/post-10826962
https://mayhew.com/news/news-full-a...-a-new-2-piece-mini-heavy-duty-hd-pry-bar-set
53958402611_5e3004be5a_b-jpg.2174482
