Point type distributor w/ no condenser...?
kevin47
Concord California
Is this possible...? I have a Toyota 5R forklift that runs ( but points look like hell ) but I can't find a condenser anywhere...How could that be...?Thanks, Kevin
Big-Foot
Midlothian, TX
If the points are only used as a trigger for some sort of capacitive discharge or other electronic ignition system, you won't need to have a condensor.
jsaw
Geneva, N.Y.
The condenser prevents arcing at the points, and prevents them from becoming pitted and burnt
kbs2244
As said, condensers save points.
Real bad point erosion is evidance of a lack of a needed condenser.
chris142
apple valley,ca
The Toyota trucks used points to trigger the electronic ignition in the mid 70's and had no condenser. The points were just a low curant switch.
Boomer343
Check the voltage at the points and see what it is. I would say if it is 2 or more you need a condenser.
Just putting an electronic ignition onto my 73 Honda CB350 and it retains the points and condenser.
Shadowdog500
Down the shore
+1! An engine will run with just points. Early horseless carrages were built that way.
The condenser was only added to keep the points from burning out too quickly.
This video discusses this.
JasonMcElroy
San Jose by way of Philly & NYC
Yes, an engine with points/dwell style ignition will run without the condenser, but it will run poorly.
The condenser does more than just protect the points from burning up, it also prevents run on contact (arcing) when the points start to open. This causes the ignition event to be late. It also happens at less predictable times.
To run without the condenser, you'd have to change the timing a bit to account for this.
Don't believe me? Disconnect the condenser while it's running and listen to it stumble. Better still, put a timing light on it and watch the line dance around with increased timing variance.
As for the original question, I think it's been answered. The points are either acting as a low voltage switching device with no condenser required, the condenser is mounted somewhere other than near the points and it hasn't been located yet, or it was left out at the last service.
Jason
