wantacoe
One corner of my pole building is below grade. With the snow melting and lots of rain that corner is under water. I don't know why they built this thing in a hole, needs to be about 3' higher. What can I do about it now?
Excavate and reroute the flow.
Bill
A lot can happen in 50 years."They" is whomever built this building about 50 yrs ago.
Possible on the french drain and run it into the dry well.
An open hole is a pond and a hazard is most places. A covered hole is a dry well.Yes, bottom line is you have to dig a hole that's even lower than current and big enough by volume to get the water level below your floor, siding, etc.
The french drain is OK for a finished residential property or its dead flat for a mile in every direction. Way too much work if you live out in the open country.
I had a local excavation company come out the other day and look at my situation. He basically said I was screwed. The ground is graded and ran away from the building. I was there during a 4" rain last summer and not one drop got in building so I figured I was safe. The problem was repeated snow, sub zero temps, rain and freezing again. The snow got rained on and froze blocking the flow. He said even with a french drain once the ground freezes water can not get to it. So I guess I just have to do my best to keep the ice down.
He said rain is not the problem. Gutters probably not going to do much to redirect melted snow on the ground.Gutters on the building would help. Run the water to the opposite end of the building. I did that on my barn. You can get over sized gutters to handle the water.
From the first photo you posted, it appears to me, that the driveway is lower than the barn....or is this not the case? If it is, trench a drain line to the lower portion f the property.
I do plan on adding gutters, it can't hurt but like CSI said they won';t do much good with snow.Gutters on the building would help. Run the water to the opposite end of the building. I did that on my barn. You can get over sized gutters to handle the water.
I'd agree with the local excavator, I'm not a fan of french drains either.
Is there a possibility of cutting a swale to direct the water away from the building?
