SI86
Any thoughts on Pole Building 8' Insulation Blankets?
Batts are pretty tough to get right. You need them to fill the cavity left to right and top to bottom without gaps as a blanket would be. You need them to stay that way and not sag to the ground. With an 8' wide roll, how would you hold it up to prevent it from sagging into a pile?
I bought from Morton also. My local building supplier couldnt even get the 8' wide stuff. Go back and look at the pics of the hangars I made. It doesnt get any easier/faster than that. I was able to hang the 8x10 blankets all alone. Push the cleat up between the top girts and twist it to hang, done! This will change depending on your building though, Mine is a Pioneer ,it has double "plates" on the top.
I agree with Reiferman,less thermal bridging also.
Also watch the video on the Morton website on their energy saver insulation,shows it pretty good.
OH, and I added some pics to my thread.
When I worked in the industry the builder I worked for (large builder, over 30 years in business) preferred 24" wide batts. Exterior girts to hold siding, interior girts to hold wall finish, and the batts would be a snug fit between. Butted side by side. HVAC pros would routinely tell me that our buildings were tight and energy efficient, and install process was easy. No sagging. Also, with post frame like I describe here there are fewer thermal bridges to reduce efficiency.
Vapor barrier generally goes on heated side of insulation.
SI86, your backwards in your understanding.
Condensation occurs when warm air meets cool surface. If you stop the humidity in the air on the heated side, it doesn't condense out when it gets to the cold outside surface.
Chris
