Polyethylene pipe fitting
bluedog225
Texas
My neighbor is an old marine, retired from Johnson controls as a construction manager. Point is, he’s been in construction for decades and decades on civilian and military jobs.
He swears there is a polyethylene pipe fitting that allows the line to slide in. Like a shark bite. He strongly recommends this instead of a normal barbed tee or a Ford/pack joint.
I can’t find this fitting. It’s possible he’s misunderstanding the water line project. But I don’t think so.
He says these fittings are 100% reliable and don’t restrict the line in the way a barbed tee would.
Does anyone have any idea what this fitting might be called?
Thanks
bluedog225
Texas
He’s up in years but still very much present. He was talking about the virtues of black water pipe.
I don’t think he’s ever seen a shark bite.
NWOhioChevyGuy
Buckeye Hill (Morenci, MI)
I was an engineering with a company that did a lot of poly, Teflon, etc. tubing and the like back in the day. Many manufacturers make tubing fittings that secure to the OD of tubing.
Pipe is controlled / specified differently that tubing, could that be what his reference is to?
Fixr
SW VA
Thanks
I vaguely think I saw something like that a few years ago, and yes, for black poly pipe, but I have nothing beyond that little tidbit. Since I have to replace my supply line, I'd like to find those. Failing that, I noticed that HD now carries some blue plastic fittings that appear to sort of screw in. I'll probably look into those and see what reviews say.
rlitman
Long Island
... Failing that, I noticed that HD now carries some blue plastic fittings that appear to sort of screw in. I'll probably look into those and see what reviews say.
The Lasco Blue Twister are for irrigation line. I would be wary of using them on street pressure.
bluedog225
Texas
He was definitely describing some sort of push to connect fitting. He said he had all types of fittings-straight, angled, threaded end, etc.
It may well have been some industry thing that we don’t have access to. Or maybe not polyethylene pipe. Though it sure sounded like it.
BrandonV
Arizona
John Guest has a ton of stuff that is popular that sounds like that (especially in Europe).
Fixr
SW VA
Ah. I hadn't looked at them beyond noticing that HD showed them on the poly pipe page. We have a well with about 45 psi, so they *might* be OK, but I won't take the chance. Thanks for letting me know.
kaffine
Henderson, NV
22-W
I much prefer brass or stainless insert fittings. For their short length, there won’t be much friction loss. I have repaired many plastic fittings underground that have broken or cracked.
Rockable
Oak Ridge, NC
Parker push to connect fittings and Legris fittings are specifically designed for polyethylene tubing. They have a SS grab ring and an o-ring for sealing. You depress the sleeve on the tub end to release the tubing. Millions and millions have been sold.
Also, tubing is measured on the o.d. and pipe on the i.d. I am not aware of any polyethylene pipe but there may be some.
bluedog225
Texas
Some interesting finds. But not seeing anything for 1.25”. Lots of options for smaller.
Rockable
Oak Ridge, NC
I'm sorry but I don't know your application. If you're looking for 1 1/4", I am not aware of any polyethylene fittings that size. What is your application? It it's water, I think you should be looking at Pex.
bluedog225
Texas
It’s 1000’ polyethylene (HDPE) 250 psi water service line. I heard a rumor of push fittings but not finding anything.
BombShelter
State of Hockey
I used to sell plastic pipe, tubing and fittings, are you sure he was talking about pressure or maybe he was thinking a DWV application?
JACO is the industry standard but it doesn't go that large for a pressure fitting. I don't remember ever seeing a pressure fitting for your size.
https://www.jacomfg.com/fittings/
Parker Hannifin is also an option but they also don't go that large
Maybe he's thinking about socket welding where a heated paddle with male and female sides is used to melt the fitting and tubing, then it's slid together, melting, creating a nice bond.
kaffine
Henderson, NV
Found another but don't know where to buy them. These specify they are NSF rated so should be good with potable water.
https://hollandsupplycompany.com/ap...Hydrosert_Mechanical_Couplings_Data_Sheet.pdf
Found a place that sells them. They are proud of them. Are you using IPS or CPS size pipe?
nmk_61802
Central IL
Maybe I'm way off base here, but isn't potable poly actually sold by ID?
1 1/4" poly then would be 1 3/8" OD.... all tube size sharkbites should work with it then:
A little google fu shows that I am somewhat correct....
Personally unless the run is substantially long, I would use a coil of pex A. Much easier to get fittings for.
bluedog225
Texas
I stopped getting notifications there were new posts in this thread.
I believe HDPE is sold and CPS and IPS sizes.
Turns the brother of the guy doing the trench works for the water company. I was able to get some municipal 250 psi pipe. And they specified these couplings, which seem to be exactly what I was looking for. Thanks all.
