OJ Bartley
I’ve done a fair amount of research into epoxy coatings, and now I want to look into porcelain as an option for my garage floor. Its not something I was originally considering, but after seeing and reading about it more on here, it seems like a great way to go.
My garage is a small single-car, at a little over 200 sq ft, and will be used for tool storage, regular car parking, and I hope to build a small workbench at the back. I want this floor to be “do it right and do it once” kind of thing, so durability is key.
Living in Toronto, we do go through hot summers and cold winters, so temperature will have an impact on whatever I decide to use. Also, water and salt resistance will be key because during the winter we drive right into the garage and can end up with a slushy mess. I’m not too concerned about the slip factor, but a tile with some amount of nonslip would be good. Glazed vs. unglazed? Textured vs. smooth? I assume there are pros and cons to each.
From what I’ve seen so far, I think ideally I’m looking for rectified porcelain tiles, for the increased uniformity and ability to have thin grout lines. I would like to also tile the concrete border around the perimeter of the garage below where the drywall starts, which varies in height, increasing from back to front. I think I have read not to grout the corner joint between floor and wall, but to caulk it to allow for expansion or movement.
Another concern is the lip at the front of the garage. There is an existing lip (maybe ½ inch) going from the asphalt driveway to the concrete pad and I don’t want it to become an issue after adding more height with tile. I have read that some people use something like this Schluter-RENO-RAMP to go from the tile to the concrete. Is this a good outdoor solution (or are there others like it)?
My thoughts were that I could have the transition ramp right at the edge of the concrete (which is outside the garage door), and build up the asphalt a little bit where the driveway meets the concrete, using that asphalt filler that comes in a bag. This should give me a nice smooth(ish) ramp inside. Something like this:
There are a lot of tile stores in the city, and I assume many would have some kind of clearance or liquidation stock so I could hopefully pick up a good tile for a great price. Since I’m not set on a particular size, pattern, or colour, I could look through what they have and choose the best. Does it sound like tiles are for me? Any thoughts or advice from those with experience?
Here’s a quick sketchup model of how I picture the garage to end up with the workbench. I think either tile or epoxy coating would add a lot to the space, I’m just not sure which way to go.
**** EDIT: PROJECT HAS ACTUALLY STARTED HERE ****
