Thanks to everyone's replies to my previous thread, I have committed to tile the floor in my barn. The area is about 23x29 (670 ft^2). Currently looks like this:
These are the materials I plan on using, am I making any mistakes?
Rent a diamond grinder to remove paint:
http://www.tooltimerental.net/uploads/3/0/1/2/30120039/floor-carpet_tools.png
Through body porcelain Tile , PEI 5, rectified, light gray in color, 12x24x3/8 from build direct (I wanted 18x18 but they were out of stock)
http://www.builddirect.com/Porcelain-Tile/-Clay-Fresca/ProductDisplay_6933_p1_10081568.aspx
Flex bond thinset from Home Depot
http://www.homedepot.com/p/Custom-B...0-lb-Fortified-Thin-Set-Mortar-FB50/100122448
Reno U transition from Home Depot
http://www.homedepot.com/p/Schluter...vibyzh&cm_mmc=CJ-_-6147012-_-11210757&cj=true
Mapei Ultra color plus grout special ordered from Lowes
http://www.lowes.com/pd_593384-1295...rentURL=?Ntt=ultracolor+plus+grout&facetInfo=
Since I had to go to a 12x 24 tile to get them before it gets too cold out (barn is heated but I didn't want to take too many chances) I am going to do a brick pattern staggering each row 1/2 tile.
I think I am all set, but do have some questions about the floor drain in the center. I will post pictures but it slopes down about a 1/2 inch locally around the drain. Do I build that up with thinset, or should I cut the tiles to smaller pieces in that area to help them conform to the depression?
