Porch ceiling ideas?
P
PCustoms
VT
Well it seems Kleer has changed how they extrude their product and it no longer has the porosity that I hated.
Will have to stop at the yard next week for a sample. Likely the most expensive option, but it's as close to 0 maintenance as can be. Don't even have to paint it.
Stopped in today to get some prices on a few things. At $40+ for a 16' I will not be using PVC.
Material still had a texture to the surface, maybe not as bad as the last time I bought it but certainly not the smooth, solid PVC I wanted.
P
PCustoms
VT
Bump.
Pine edge and center is going to run me about $1800 (prices are a month old, I'm sure it's gone up).
Plywood beadboard is about $700.
Gonna just staple up some blue tarp at this point.
mike93lx
Richmond, VA
Bump.
I'm about to pull up 600ish square feet of good condition oak flooring. Free to a good home...
P
PCustoms
VT
Bump
Rest of repair/refurbishment done, pro start the ceiling in a few weeks.
Looked at the beadboard paneling at HD, not my thing. Need to look at the material at the yard again, but that was $48 per sheet. Only other realistic option I see is nickel gap or pine edge and center.
globalmax
Greensboro, NC
Bump
Did you get a chance to look at this someone mentioned a while back? https://qualityedge.com/products/soffit/porch-ceiling/
Jeff C
Durham, NC
I’ve always been a big fan of tongue and groove 1x6 boards but they’re time consuming to install. My personal preferences are pine edge and center bead painted or cedar v-groove clear coated depending on the style of the house. I’ve seen some cypress that looked good clear coated as well but prefer the warmer colors of the cedar.
P
PCustoms
VT
Life (and death) got me off this project for a while. Weather looks iffy for any good outdoor activities this coming long weekend so thinking I might tackle the ceiling and trim. Ordered the SS brads today but another $2k in wood is hard to stomach...
P
PCustoms
VT
Coming back to this.
After looking at options, my budget and overall style of the house (cheap 80's ranch) I decided $2k in premium pine was excessive.
I looked at the 3/8 beadboard panels and almost went that route but decided the tight spacing didn't look right in this space.
In the end I went with 7/16 BCX plywood and used a 90 degree router bit and guide to V-groove every 6". The long edges got a 45 degree chamfer to match. The seems are caulked and then pressed tight. I had to add some strapping, but the panels are screwed and glued up on a 12" grid with trim screws, all holes caulked.
Needs some trim and a final coat of paint, but looks just like tightly installed V-match pine:
P
PCustoms
VT
Looks nice. Curious to see what its like once the lighting is in
6 of the 7 halo showed up, should see the 7th tomorrow along with the hole saw.
Still 87F out there and no breeze. Stood around looking things and contemplated cutting/trimming the hatch, then said F that.
Probably won't get into the attic to run new wire from the junction box until Saturday morning.
