blacksuit99
- Joined
- May 21, 2007
- Messages
- 91
Well got the stand done... did I mention I work slow? Got the on/off switch mounted and turned some spacers for the handle mount. Very steady now.
But it really is nice. I did fabricat the sliding fence though. The extended upper blade guide works great too. The saw cuts straight and true.I almost feel like I cheated buying a SWAG tableBut it really is nice. I did fabricat the sliding fence though. The extended upper blade guide works great too. The saw cuts straight and true.
Well got the stand done... did I mention I work slow?...
No mill required for that either. Its just a piece of 3/4" x 3/8" bar stock and a piece of 3/4" angle welded together. I used a precision machinist square to get it to a perfect right angle before welding. It took less than 30 minutes to make.
I think he's talking about the slot in the table
The pins are so the whole stand doesn’t slid when cutting metal. They go in from like in the photo.
Btw if anyone out there doesn’t have a portaband, you need one!
Thinking about adding this laser line gizmo![]()
