Just like a window air conditioner except I have no windows.
...and it works great.
No. Single-hose portable air conditioners do not effectively deliver their rated BTU because they take air from inside your building, and blow it outside through the hose. Every bit of air the unit blows outside has to get replaced inside your building, otherwise it would run out of air. Right? Obviously you don't run out of air, so where is all that replacement air coming from? That's right. Outside. So every cubic foot of air that portable AC blows out the hose ends up pulling a cubic foot of hot humid air back inside your building.
On the other hand, a window AC separates the components. The "hot end" of a window AC is contained entirely outside and the cold end is inside the building. The cold end just recycles the cold air inside, and the hot end exclusively uses the already hot outside air to do its thing.
In general, in a place with 90 degree days, a portable AC will have be 1.5-2x larger than a window or through-wall air conditioner to provide the same amount of cooling. Basically if you have a 14,000 BTU portable unit, an 8,000 BTU window unit will provide the same amount of cooling while using much less power.
It's great your portable unit keeps your shop cool, but unless it's a two-hose unit, it's using far more power than a window air conditioner would.
