vettelvr75
I had made my first post on the "show us your welding projects" thread, but this project for me is something that will be going on for a little while as I add stuff and tweak my current design as I build. So I decided I should start a thread dedicated just to the project alone. I will insert some pics below of what I have currently.
What I have planned to do from this point on:
-Fenders to rear tires for protection from welding.
-Compartments for tips, other welding accessories.
-Compartments for misc. hardware
-36" straight edge with measurements on the front edge of the table top for making quick measurements. Allows me to make measurements without fumbling around a tape measure or square.
-MIG gun holster
- Hitch receiver input so I can quickly add/remove a vise, miter saw, etc. to table
Stay tuned for more crazy ideas that come into my head as I build it!
Also, take a look at the current progress and give me any tips/advice/suggestions/ideas you may have. Im only 20 and have been welding for a few weeks now so I am like a sponge, I am thirsting for more knowledge! Thank you guys so much!
Here is the frame of the table-
The first picture after getting the basis assembly done-
A random picture as i was doing some work. If you look on the left, you can see one of the first additions: a cross bar to hang clamps on-
To hold the pneumatic tires on, I welded a 5/8" bolt which acted as the axle to a 1/8" plate approx 3"x2" and then welded the plate onto the frame at the proper height for a level top-
One close up of one of the welds I did. I found this tray that had a motor mounted onto it that was made out of 1/8" material. It was the exact size for my welder to sit in.
So I just used it to set my welder in so it doesn't slide while moving the table. I know i should have cleaned it more, and I had every intention to do so but I have very little time to work on my table so I felt i needed to make the most of it! if it were structural I would have taken the time.
-MIG gun holster
