Porter Cable 18V Battery
pudgybear
Brooklyn Michigan
I have a P C 18 Volt battery and it doesn't seem to want to take a charge anymore, I put it on the charger and the red light just blinks, My question is how can I check to see if it is shot or what is the matter?
6PTsocket
You can measure the battery voltage with any cheap voltmeter. Do you have another battery that charges? That would suggest it is shot. Replace it. Neither charges would suggest charger problem.
icu2tsx
Minnesota
One possibility is to try jumping it with another battery. Plenty of youtube videos on how to do it. When battery reaches too low of a charge or has not been charge in a while. The charger won't charge it.
Happen to me with the first and last ryobi battery I owened.
Sent from my SM-G900P using Tapatalk
woody6904
NW Ohio
I still have some porter cable 18 volt stuff. I have one NiCd battery that does the same thing you describe, blinking red light, on a Lithium/NiCd charger, but if I stick it on a straight NiCd charger it charges and works fine. Glad I kept the old charger.
6PTsocket
NiCds grow thin fingers of material across the battery plates shorting out that cell. Forcing high current through the battery blows them out like a fuse. When this process has started the battery is not in good shape and has already lost a lot of capacity. It often brings them back for a while but the fingers, called dendrites tend to grow back.People use all kinds of things like car batteries, welders, power supplies to blow out the dendrites. You dont repair a problem without confirming it. This is not the best thing to do to a good battery. Measure the battery first. If it reads nothing it is probably open and a lost cause. If it reads low by some multiple of 1.2 volts probably that many of the cells are shorted and it is worth shot.
