Post frame interior girts
wewiserangers
Finishing the inside of pole building on my own. Posts are 8' on center. Walls are 16'. For drywall what girt size and spacing should I use?
2x4 or 2x6?
Firebrick43
West central Indiana
2x4 or 2x6?
Is the outside sheathed in OSB or use heavy gauge (22) R panel? Where do you live? There might be too much bending in the 16' walls with drywall
Face mounted to use blanket insulation or book shelf girts for batts?
Face mounted in barndominiums is common to use 24' long 2x4 on 24" centers with 5/8 drywall. I would use Type C drywall with its higher fiberglass content and better fire resistance.
jack stand
Lakes Region Maine
Just build a 16' wall - 16" on center framing slab to ceiling flush with the posts inside face.
This is what drywall wants and you can get a better insulation with normal fiberglass batts .
In Illinois I'd put a layer of foam against the metal and in between the wall girts and foam the seams against anything that might let air in to seal the wall cavity then build your walls.
