Post your random questions about welding
05snopro440
Sherwood Park, Alberta
weldingtipsandtricks is a good chanell. theres other good chanells but wtat probly gets my first vote. ive watched hundreds of videos and wtat is as good as any for learning but ive picked up tidbits of info from other chanels as well. if you have time for books the jamesflincolnfoundation has good ones for cheap
You can also get those Lincoln foundation books for free in some cases as a PDF from Lincoln Electric's website. I just googled the name of the book I was interested in and there it was.
120v SMAW with the smallest gun possible that takes a 10 b spool. I have a 100a century that I love for this kind of work. Personally I find the Lincoln and Century welders have a softer arc profile that works well for body work versus the Millers and Esabs but not everyone notices it.
SMAW is stick welding. Since you're talking about a 10lb spool, I assume you mean FCAW (flux core).
matt_i
What I was taught is that the AC weld on aluminum keeps the oxide layer "broken up". Despite the inert gas bath its somehow prevalent underneath the gas shield and is more tenacious than that of steel.
Relative to high frequency, that's a pulsed voltage "ripple" which helps to ionize the air-arc-gap more quickly. If you thought of a graph and your DC was a horizontal line, a sine wave would be superimposed on the line at that level, instead of the sine wave being centered around zero and having equal positive and negative swings.
I've taught a few people to start to tig weld - not to build race frames out of titanium but just brackets and such, I have them cut 2 pieces of 1/4 x 1 steel flat bar and lay them side by side (with benchtop grounded). I setup on a corner of the bench where they can get very close and look directly at what I'm doing with a second helmet to demo the process. Then on their own, use No filler rod, just focus on moving the puddle around, not dipping the tip, and eventually following the gap to fuse the pieces together and think about the metronome in your head. The most common mistake I see is that the torch gets laid over to the side too far and the puddle gets really elliptical. Like anything if you are driven enough to research, watch videos and try to improve your techniques by taking on different jobs and practicing often, you will get better at it.
speed bump
Butte Montana
You are correct but in the case of the original question I should have said GMAW as they were talking about sheet metal.
bdbecker
Iowa
You can also get those Lincoln foundation books for free in some cases as a PDF from Lincoln Electric's website. I just googled the name of the book I was interested in and there it was...
Great resources for sure. I ended up getting hard copies of a few of the books after using the PDFs . For the price, they can't be beat.
Adding a link in case anyone is interested:
ntsqd
Lower left coast
I've got this Coyote, and a Palm Tree. Need suggestions for the best filler rod. I'm thinking to attach the Yote in the "going away" position rather than the head-on position if that matters any.
GTAW is my preferred process, but I can splatter on something that vaguely resembles a weld bead with a GMAW if forced to.
V
VR6ix
Onterrible, Canuckistan
Asking the hive-mind collective again, before I go and make something custom...
Are there any extra-long back caps on the market that allow a 7" tungsten to work with a stubby cup? On a 17 air torch.
And bonus question, a 17 torch back cap thread is 3/8-32 ultra fine thread, correct?
:beer:
GaryM909
Calgary, Alberta, Canada
:beer:
I had a 3/8 tap for those. I am not sure of the thread count but it's the same as the threads you will find on light fixtures
bdbecker
Iowa
:beer:
Yes, 3/8 x 32 is correct.
As far as back caps go, is the 300L/57Y02 not long enough?
V
VR6ix
Torch is a CK CX17 FX. Came with the 3 backcaps but no part number markings on them.
6" electrodes fit fine with the long backcap and the stubby cup. 7" electrodes offer a little bit too much stickout for most applications :dunno:
I'd rather buy, or make, a longer backcap, than buy a set of standard-length cups and not use the stubbies until the electrodes are short enough. Tempted to modify the long cap I have, cut it and epoxy something in to make it longer... I have enough varieties of 7" tungsten blends to last a looooong time!
Jswain
Calgary, AB
Not ideal but you can cut the tungsten in half, then you can use a shorter back cap as well.
Just have to stay organized with your tungsten, or if you only use one type then no worries.
bdbecker
Iowa
...7" electrodes offer a little bit too much stickout for most applications...
I missed the part about using a stubby cup... I see the issue now. If you decide to modify a back cap, you'll want to make sure that it is air tight and won't leak once you have shielding gas running through it.
It might be worth contacting CKW to see if they have any tricks up their sleeve. You can't be the only person who's wanted to run a setup like this. Heck, maybe if enough people ask them about it, they'll bring an extra long back cap to market? You never know...
welder4956
Birmingham, AL USA
I think that is the down side of using the stubby gas lens on a large torch. I don't think anyone makes a "ultra long" back cap for the 17 style torch. If you were using the smaller 9 style torch you can get a 41V24L ultra long back cap, but the threads are 5/16" so it won't fit the 17 style torch.
2023-11-09 13_41_07-WeldingCity 2-pk Ultra-Long Back Cap 41V24L for TIG Welding Torch 9, 20 an...jpg
