Douche bag meth addict squatters stole everything from the shop so a friend gifted this chain saw that hasnt run in a year. I hope the coil position is terrible critical. I used a feeler gauge at .014” . I have a good spark i guess.
I suspect bad fuel lines.This was attempt to troubleshoot this saw. New: gas, plug, i have spark, cleaned carb, checked the coil gap (hit or miss). still a no go. Ordered a kit to replace the carb because I suspect the diaphragm.
This new Poulan pro I got first started out rough on Low idle speed. So I buy a 21T Spline to adjust carb. Got that squared away at the same having another trouble (The main one!)
Having run a bit and all warmed up,(Running great on low idle) the choke pulls in and it dies. I have even tweaked more Low idle a little to see if thatsit! But that choke ain’t haven’t it. It just pulls itself right in a dies.
Does anyone have this ADVANCED KNOWLEDGE to help me??? Because I’m realizing through reviews and now expierience that these are freakin **** but will do the best I can to maintain it!
The first thing you should do is remove the muffler-2 screws, which will expose a small cross section of the piston. With a flashlight look for scoring on the piston which will bring engine compression nearly to zero.My first Poulan Pro 4218 was sold at half-price because the first owner couldn't get it to run. The store employee adjusted the carb, got it running good, and sold it to me. (I owned it for two or three years, not a lot of use until early summer this year. Locked-up on my nephew after two days of hard use. This then led by to buy the second one.)
So my first guess is to adjust the carb--is there a low-speed screw and a high-speed screw?
If no high-speed screw, perhaps there's a pinhole in the fuel tubing, or debris in the carb restricting fuel flow so that it needs the choke to run.
