Powder Coating?
555
Nomad-Arkansas & Georgia
Thank you! I have everything to start powdercoating at home but I've never started doing it. It's on my bucket list and your guide has provided a lot of information.
Regards,
John
99ishvr4
Florida
Bumping this thread to see what people have been coating. Post up your recent powder coating pics!
flat tire
hills of wv.
I didn't do it. I had the intake and timing chain cover done with CERAKOTE in front royal va.
J Persons
Louisiana
Regards,
John
Join the powder365.com forum. Lots of tips from pros and lots of good deals on powder and supplies.
Here's a photo of a valve cover I did as a test. It's metallic gray with a clear coat over it. It actually needs another coat of clear
roll_the_dice
Savannah, GA
I just started powder coating in the last few weeks. I have really enjoyed it. I have a TP Tools blast cabinet and an Eastwood powder coating kit. I need to get a larger oven off of craigslist when I get my shed built.
I did my brake calipers in a basic Porsche yellow with powder clear coat and I am doing my buddies brakes as well since he did my brake install in a candy red with a chrome base and clear on top as well. Here are a few pics of mine and his..
Rear brake caliper
Installed
Chrome base coat on friends caliper
Candy Red 2nd coat
CudaChick1968
Member Emeritus
Northwest Tennessee (38230)
Nice work there roll the dice! Calipers are a PITA.
Pull those silicone plugs after you spray but before you cure (give 'em a little twist as you pull). It'll leave the threaded openings smoother without any 'tails' and also save you the hassle of having to clean cured powder off of them afterwards.
My shop is celebrating its 10th Anniversary on May 31!!!! The time has flown by and the projects never fail to keep me inspired. Here's a few from my bench ...
roll_the_dice
Savannah, GA
Thanks, I appreciate it! I read that about the plugs, but after the fact. I was also afraid of bumping the part and screwing it up! :D I can definitely see where doing that would leave a much better edge.
Congrats on your 10 year anniversary! That is awesome!
roll_the_dice
Savannah, GA
Now you got me interested, what is a good gun for a newbe?
My wife bought me an Eastwood dual voltage powder coating kit for Christmas last year. It included 5-6 powders, a small oven and the gun. I am going to eventually buy a used oven off of craigslist so I can do larger parts.
The Eastwood stuff is cheap enough that if you don't like doing it you aren't out a bunch of money. I have thoroughly enjoyed powder coating so far. I am starting to restore my 1965 Chevy C10 soon and will use it on some of the engine bay parts...
J Persons
Louisiana
The only problem I have with the Eastwood gun is that I clean up the gun outside, and everything, the transformer and all the wires have to go outside with the gun. I do this because my shop is dirty enough and I don't need spent powder everywhere. If they would just put a disconnect at the gun, life would be much easier.
J Persons
Louisiana
I want to coat some bolt heads that have an oil and phosphate finish. Will bead blasting be enough to remove the oil and phosphate finish? I plan on soaking them in acetone after blasting.
