Carquest
Has anyone bought, or made, anything like the power drawer available on the Snap On boxes that holds your cordless tools in a deep drawer?
Here is the part number and pics...
Your welcome!Thanks again!
I built my own using the Snap On plastic holsters. I used 18 ga steel and bent it to fit my drawer. I used 1/2" hems along all edges for stiffness and to get rid of any sharp edges where a hand or tool might be. It's not a "power" drawer as I don't have any charging capabilities, but for me it's a much better storage solution than just throwing them in.
Do you have any idea what the difference is between part# 843AE5000 that you ordered and part #1098J5000 that was previously mentioned in this thread? Is the one you ordered longer?I have a KTL1022A coming tomorrow. I ordered the organizer also.
Part#: 843AE5000 it was $273.
I'm going to try to fit the power drawer either in the same drawer or the one above it, if it fits....
Part #'s: Wire harness assembly: 30AEP200 - $208
Stainless assembly with plug, etc: 30AEP249465R - $349
Thanks. I was able to figure it out with some Google-fu… The 1098J5000 is from the KRL1098 boxes (hence the 1098 prefix) and is intended for drawers in a 29” deep box. The 843AE5000 is from the KERN843 boxes, and is intended for drawers in a 30” deep box. I wanted to post this here before I forget, because I have model numbers all over the place right now…I think it must have been for the Epic box. Mine is about 1/4" too long. It still works, but it's jammed in there.
Thanks. I was able to figure it out with some Google-fu… The 1098J5000 is from the KRL1098 boxes (hence the 1098 prefix) and is intended for drawers in a 29” deep box. The 843AE5000 is from the KERN843 boxes, and is intended for drawers in a 30” deep box. I wanted to post this here before I forget, because I have model numbers all over the place right now…![]()
There is no crimson or maroon ANYTHING in my garage… You can probably guess why LOLI HATE the red trim color I have, but I got a killer deal on a brand new box, so I'll be changing it from red to black. It looks like a Alabama Crimson Tide box. And I'm not a Bama fan, soooo......
It's supposed to go under the tool holder in the orientation that's shown. But I couldn't use it in mine becuase I ordered the wrong one. It really doesn't seem necessary tho. I dunno.
Any chance you can measure the inside dimensions of the large and small snap on holsters? Trying to figure out which ones I need to hold a variety of different toolsI had someone send me a PM asking for part numbers and looking back at this I noticed they weren't included so now they will be.
Small holster = 1098APA02
Large holster = 1098APA03
M12 stubby impact needs a large. CP7732 (8941077320) 1/2" compact impact uses a small. Astro Nano 1828 impact uses a small (had to use a heat gun to warm the plastic and make small adjustments). M12 drill and impact driver both use small.
Did you end up returning 843AE5000 or holding onto it? I ordered 1098J5000 for my Extreme Tools 72" 17 Drawer, unfortunately it doesn't fit width wise. It looks like the 843AE5000 is significantly narrower, but it's even longer? If you kept yours could you measure how long it is?I'm going to return the one I have and order the right one.
Would you mind sharing how deep your actual drawer is and how much clearance you have? My drawer appears to be ~26 15/16" deep, I'm wondering if 843AE5000 will fit?Figured I would post a pic of the fit of the 843AE5000 holder in an Extreme Tools 72x30” 19-drawer box:
My drawers are the same depth - if memory serves, I had to assemble it inside the drawer because of the lip on the front of the drawer:Did you end up returning 843AE5000 or holding onto it? I ordered 1098J5000 for my Extreme Tools 72" 17 Drawer, unfortunately it doesn't fit width wise. It looks like the 843AE5000 is significantly narrower, but it's even longer? If you kept yours could you measure how long it is?
Thanks, it looks like 843AE5000 might have been a better choice for me but Snap-On won't take back the one I already ordered. For now I'm going to set it to the side, I might circle back and see if I can find someone with a metal brake to bend the one I have now.My drawers are the same depth - if memory serves, I had to assemble it inside the drawer because of the lip on the front of the drawer:
