Power to new Building from Existing Meter
Bert_
NW Iowa
You could run those hookups off a 100A service without a problem. Would still have enough for lights, odds and ends in the building. If you want to condition the building that could be a factor. Big A/C would take some power.
Get the 8000 alloy aluminum. It bends easier than copper even though it will be two sizes bigger
Terry D
St. Louis, MO.
Aluminum bends way easier than copper. Keep it all aluminum from start to finish. There would be no advantage to switch to different conductors. I would talk with a HVAC contractor to see different options. Are you considering heat also.
K
kool55
South Central VA.
Heat not so much. Hate the heat with humidity in the Summer My 40x60 shop is fine in the Winter.45- 50 degree is fine for me.
