vavet
I've seen several ways people use 3 or 4" PVC that they notch and hang up to serve as holders for the cordless drills, impacts drivers, etc. I like that idea and want to use it. I have the Gladiator RTA (ready to assemble or the less expensive) line of cabinets in my garage. They're thin sheet metal- 0.036 inch (20 gauge?)thickness.
The bottom has a flange around it that fits a 2x4 nicely. I'm thinking of taking one of them off the wall, fitting a 2x4 widthwise and running a couple screws from each side through the sheet metal and into the 2x4. The PVC pipes could then be attached to that 2x4.
I don't love the idea of drilling a hole in the floor of the cabinet to add additional screws, although I know that would make it stronger. there's no way to countersink it with the metal being that thin and I don't want a screw head on the floor of the cabinet where it can snag or interfere with whatever I put in the cabinet.
I feel confident my solution will work, but I thought I'd see if there are other better ways to do this.
Both were #10 Machine screws IIRC. I have more to do soon(ish) I'll add pic's if that timeline works out. If you want to use flat head wood screws to attach, I would make a form, by drilling and tapping for the screw size you are planning on using [10-24/32 with matching machine screw for the form and a #10 wood screw etc.] (steel or aluminum would be best and be re-usable for the future) with the same C'Sink outlined above and again just use a machine screw to form your C'fer. Harry
