I have a '46 power wagon body on my 12 valve mud race truck on a shortened 96 dodge frame. Good work so far.
Here is my spooling up at the starting line:
I used a 96 Dodge's frame, not a power wagon frame, so our mountings are different. I used the stock engine mounting location on the 96 frame. I'm in the middle of pulling the engine to change cams, put a new fully worked over hamilton head on it, longer connecting rods and cutting the tops of my pistons to increase compression. Shooting for over 1000 hp for next season. Also looking into what it would take to move the front axle a foot forward so that the axle is positioned under the dampner to get a better weight distribution on the truck.
Fender turned out real nice, Mike. Nothing to this dent removal stuff, huh?
Looking good, the pedals are going to be tight. After Dad did his transmission tunnel there was barely any room. Steering linkage was fun too. His was with an F350 diesel drive train.
The wagon is awesome. Can't wait to see this completed! I think you have the only truck I've ever semi-liked those wheels on
I'm basing it off of using the regular boots I wear (5" at the widest). I've got 13" of room, could gain another inch if I were to not install the kick panels.
The pedals don't have to be real wide, maybe 2" or so. It will be tight. I don't think there is a way for me to use the factory pedal box like I did in the photo. Easy enough to make a custom set though.
I switched to the earlier NV5600 6 speed, it will be here tomorrow.![]()
rear panhard is too short and the bracket support is a little lacking, plus might be a cold weld there on the back of it.....axle tubes are thick, turn up the heat.
What's the option/feasibility of shifting the engine & trans toward the passenger side a couple inches for additional room for boots?
how far into the cab does the engine poke , I have the possibility of picking up a Fargo power wagon I believe its a 48 . I would like to put it on my 1990 w250 cummins frame if possible , your build is looking great
Subscribed.
Fantastic craftsmanship.
Thanks for sharing.
Nice Wells Index milling machine also. By the looks of it, I am assuming it is one of the larger ones, 10"x54" table?
Mike.
sure, send me a ticket!![]()
Nor'Easter,
Looking great, I love the build!
Here is mine after I completed the stake Bed.
I agree on the rear pan hard length. Run another pass on the tube, add a couple gussets, and leave room to put in a longer one later (if you don't want to fix it now). Or tell all of us to shove it and keep building! Keep up the nice work man!
Pan hard is staying for now. Under normal operating travel the lateral movement is only around 1/4"....anymore gusseting to the passenger side would contact the bag under full compression.
Thanks. It's a 747 so, 9x46.
you're right of course, but if you're towing with the rig and a cross-wind starts pushing that big cab around, that 1/4" could be a problem. longer rod, less angle, less lateral, blah blah.
as for bracing, what about an over the top truss?
not a real good pic but if you zoom in you'll see the truss where the UCA bolts into. 3/4T d44.
i'd like to see the upper TB mount on the outside of the frame rail behind the axle and the lower as far as practical on the back of the axle tube.
if you keep front & rear TBs the same length then you're axle movement will feel much more natural and driveable, especially if towing.
