Precision straight edge, beveled or flat?
okie18
I'm needing a straight edge to check head and deck flatness. A flat edge would work for what I want but I'm curious as to what a beveled edge would be used for? Advantages/disadvantages?
larry_g
oregon
A wide edge is more likely to pick up debris and skew the reading.
A wide edge will more likely pick up the high spots/burrs on the surface..
A wide edge edge will block more light if using a visual check.
A wide edge is less likely to suffer damage from poor handling.
It also matters a bit if your just checking to see if it needs to go to the machine shop or if your the machinist that is doing the work.
lg
no neat sig line
rsanter
visalia ca
The commercial straight edges I have for checking head and deck flatness all came flat, no bevel
tarmy
Nor Cal
Flat...both sides. I actually have never had a need for a beveled side...handy tool.
O
okie18
10-4. I'm just checking the block, the head is going off for new seats.
After thinking, a beveled edge would be a pain to check flatness with since you'd have to balance it while checking with feeler gauges.
Larry, I follow you on the points you made. Then I answered my own question above haha. Thanks guys.
Now off to find a 36" straight edge $$$$
Sent from my SAMSUNG-SM-G890A using Tapatalk
tarmy
Nor Cal
Figure out if that will fit in the situation you have, if the engine is in the car...36" may be too long...
O
okie18
It's a 5.9 cummins, so it's close to that but I still planned to measure to see it it would fit.
O
okie18
I'm just checking fleabay and searching Google.
