Preferred vintage craftsman table saw
Mustang67ford
Looking to get an older cast iron craftsman table saw. What model shoukd I keep an eye out for? There is a model 113.27610 I seem for sell completely redone on a metal stand for $250. It seemed a little pricy to me but have not researched them much.
subroc
Dover, NH
I have no clue what any old thing is worth. I only know what it is worth to me. Lot of things to look at when selecting an old saw. That is a nice looking model to be sure. Similar to the 113.27520 a saw that there are a lot of around
As far as the 113.27610 saw, I know little about them except to point out it has a slightly different miter slot location that is questionable. Note how narrow the miter slots are on that particular saw. If a standard craftsman miter gauge is used in I am reasonably sure the left slot I believe it will or can hit the blade. If you look around the web you will find some old forum posts that highlight that curious design "flaw".
Other than that if you find a good one for a reasonable price it could represent a value.
Hope you find a good classic saw at a fair price.
Here is a link that shows that particular. Note the alignment of the right side of the miter gauge and the blade.
link
That price is high unless you are a collector and looking for one that is in "like new" condition.
Stay away from any that do not have a belt drive. Also look for one with a 10" blade and 2 cast iron table extensions. Lightly used, but left to rust, one like I just described, from the 70s-80s routinely sell for $100-$150 around here. Some steel wool and some WD40 you can make the table look almost new again in under and an hour.
driftpin
It's always good when the poster has his location posted below his avatar/screen name, so you know if anything you can offer is an option for him, or if he's across the continent.
A friend of mine in Wellington FL has a BNIB Craftsman 10" table saw be bought in about 1988, when he was building his house (having it built). It's never been used.
mikegt4
sw ohio
It appears that vintage Craftsman table saws are a big business. Recently I was looking for a small vintage table saw to do small quick cuts instead of digging my big Delta TS out from under piles of stuff in my garage and wheeling it outside for a 10 second cut. Lots of beat up rusty CM saws at ridiculous prices. I ended up with a solid Delta 8" 34-500 saw for $25. A bit of cleaning, new paint and bearings and I now have a nice little "quick cut" table saw.
Here are a couple of resources.
subroc
Dover, NH
Clearly, if you have space for a 2nd table saw that is a great solution. How big is the footprint? What is the length/width of the base? Also, what is that particular saw top size?
BTW, looks good.
jonshonda
Wisconsin
The CM 113 is very popular. Bolt a Beisemeyer fence to it, and you will get a very nice saw for the money.
Mustang67ford
What model?
mikegt4
sw ohio
BTW, looks good.
Being a 8" saw the table is small which is what I was looking for. The table itself is 22'"deep and 15" wide. 5" extensions were available for each side making the total width 25", I don't have any extensions. The motor probably adds about 10" to the depth. These saws had rails front and rear for the fence, they are about 33" long and are quickly attached/detached from the table reducing the storage footprint. The PO had the rails but couldn't locate them when I picked the saw up. Not unexpected as he had a 60x30 building stuffed to the brim with equipment from a machine shop business that he closed down. I am going to make a small scale Biesemeyer style fence for it. Original rails on Ebay approach $100 these days. I am in the process of making a base for it, the one that it came with was in poor shape, probably was an old wood packing case that someone adapted. It did burn spectacularly in my fire pit. BTW, the saw's serial # indicates that it was built in 1950.
My intension is to use this saw for small and quick cuts, for anything not in that scope I use my big saw, it just takes a lot of effort to get it out of the garage and run a 240V extension cord for 15 seconds of use. This little saw runs happily on 120v in my basement.
If you are shopping for a vintage Craftsman or Delta the VintageMachinery.org site is the best way to learn the different models. I went through all the photos and determined the models best suited for me. I just ran across the Delta on CL and watched it's price fall over a month's time and I think that I came out well for $25. You can select the type of tool for the seach then prioritise model, size year etc. by clicking the description at the top of each column. I spent hours just running through the VM pages, there is a huge amount of info there. Here is the Delta link, one for machines and one for publications (owner's and parts manuals) Good luck on your search..
subroc
Dover, NH
Thanks for the info. I am very familiar with vintage machinery.
I have a small shop. So every footprint matters. Further, in many cases a small tool on a stand with rolling base can be similar, footprint size, to much larger machines. But, if you have the space, none of that matters.
it looks like you have a solid plan in place for the 2nd saw. Enjoy your saw.
Mustang67ford
Just picked up a small craftsman dunlap 103.0209. I think it is 7". Now very big, but seemed unique.
mikegt4
sw ohio
My Dad had a Craftsman 8" 103.24242 which is about as small as a CM or Delta gets (17" table depth). Despite it's small size it was a real work horse. I think he got it in the late 1950's, we used it to cut wood for a small sailboat and I used it in the 70's to cut all the wood for a 37' sailboat. Probably went through 3 motors during it's life, should have used sharp blades instead of burning our way though boards. Sadly it was stolen at the marina along with a bunch of other tools. It served as the inspiration for getting a small table saw as a secondary.
JosephLaur
I’m a huge fan of late 40’s to late 50’s eta Craftsman saws. I use me 10” Unisaw as the heart of my workshop, but always have my 8” 113.27580 nearby, often set up with a dado set so I can just nip over there for those. If I could only have one saw to combine beauty and function, I’d have a 113.27520 10” Craftsman with a 2hp upgrade.
I buy and restore these as a hobby. Those beyond functional restoration, I’m looking into creating tables out of. They are works of art.
Here’s mine-
Packard V8
Spokane, WA
Be aware there are dozens of variations of Craftsman table saws, 8" and 10", differing table widths and lengths, different rip fences, different motor horsepowers, aluminum and cast iron extension wings. Some are heavier and more valuable than others.
FWIW, the value of older table saws has tanked in my area. Younger guys are terrified of old table saws; seem to feel if one walks near anything which isn't a SawStop, it's likely to roar into action and rip one's arm off. In the past century, I'd buy Craftsmans needing a lot of work for $25-50, , throw in new bearings, belt, motor, pulleys, whatever was needed and sell them for $250. In this century, I've been given similar projects just for hauling them away and then been unable to sell them at a profit after all my work. Today, I don't rebuild them.
Another FWIW, when Craftsman table saws became so cheap here, I bolted together two saws and two extensions to make a huge table and kept one trued for 90-degree cuts. I then added a Delta Unisaw Unifence which someone had junked to install an aftermarket fence. That made a very versatile saw for cheap.
Pro tip - the motor hanging off the rear can torque the trunnions out of alignment. I always added a locking bolt to the rear trunnion to match the one on the front trunnion. To accurately adjust the blade, remove the belt and the motor, so the motor isn't fighting the adjustment, use a square or an angle gauge to set the blade to the angle you want, tighten both trunnion lock bolts and then reinstall the motor and belt.
jack vines
seber
Deep East Tx.
Down here in Texas that might bring $150 to $200 if it has both wings and is in very good condition. Be sure you check the fence for consistent square lock. A lot of those have to be set with a square every time.
J6R
Here’s mine-
Joseph - those look great! I have a very similar one I’m cleaning and putting a new motor on. However my Model plate was never on this saw, it was in the family for at least 50 years plus. Is their a way to tell what exact model i have? Many of the castings have (part?) numbers on them, however they do not match any part #’s from multiple Craftsman’s manuals i have printed. Also is there a good place to look for any original parts? Thanks for your help.
exmaxima1
Midwest
That is exactly correct---every change in the fence requires checking with a square and (ideally) locking down the end of the fence with a clamp. I lived with that procedure for decades until I upgraded my fence to a Biesemeyer. The fences on those 50's CM saws are terrible.
janegoering
I have that model and would like to sell it. I have not dusted or cleaned it for the picture - sorry! I am cleaning out my shed after my husband died. This saw belonged to my dad who bought it new in 1950. You have probably found a saw by now, but if you could give me an idea of what this is worth, I would appreciate it. Thank you! Jane Goering, Nebraska.
