) . Looking great!! Enjoy it. My MaxJax-
The next plan is to finish the garage,.......finally !
Flooring will be the interlocking tiles from "Swiss Trax" ,like the "Race Deck"
I will be having a "Group Buy" on "club cobra" ,if any of you would be interested, just let me know.
Nope, it's actually 4.5" from the edge to the plate, not the bolt so, it's apx.
5" to the bolt. If you look at the photo, I built a second dummy wall to house some of my scale cars. That's why you think the column looks close to the garage wall.
I will someday, cut out in between the studs and slide in my acrylic box's and place in the cars. They will be flush with the wall and will have LED bulbs to light the cars up. Hope, it's cool when it's all done,.....someday.
After mocking up my Maxjax post layout I find that I have some cracks in the concrete near where I will be bolting the posts. The cracks are not huge and none are closer than 12" of the posts mounting points. My slab is 4.5"
Should I be worried about these.
G-Force I find myself asking the same question, My slab is 4" of 4kpsi with wire mesh. I have some long hairline cracks in my floor. I emailed Dannmar and they said as long as you are farther than 6" from the cracks you should be good, of course the cracks on my floor are within 6" of where I would plan on mounting the thing :-(.
I didn't get too many pics of the install today as I was doing it by myself, but I will get some better pictures when I get the time, and do a little mini review.
One more project to wire up this week...
Hey Gabe,
You snagged both wall cabinet and air hose bargains at lowes. I'm so envying you...
where did you get that air compressor? I'm thinking about upgrading mine as well.
I anchored down my posts today finally. 9 out of the 10 anchors went in PERFECT achieving 100 ft lbs at about 1/8"-3/16" below the concrete.
The anchor that I had a problem with started to deform when I pounded it into the concrete. It took A LOT more pounding to get it set 5/8" below the surface, and it barely raised at all to achieve the 100 ft lbs.
This should probably be fine don't you think? Since the anchor is still biting and easily able to grab 100 ft lbs.
It's one of the anchors to the side of the post.
Tho only other thing I noticed was that when I swing the yellow arms all the way out to the side of the post, they scrape on the concrete floor, but maybe that's just an issue of an unlevel surface (although they all do it exactly the same)
still waiting for mine to arrive after some misunderstandings on my part..........i suggested making up a steel template for the mounting holes and moght go one dtep further and make up 1/8 steel shims as well..........sorry to hear of the issues others are having but will be applying others lessons to my install and hopefully it will be trouble free........yea , right![]()
