Pressure Washer. Adjustable Water PSI ?
427HISS
I have a Briggs & Stratton 190
8.75 EXI
2600
RPM3100, PSI
Can I place a ball valve before the outlet (sprayer) so I can reduce the pressure of the spray for smaller items to large, without hurting the unit's pump ?
rust in the eye
Chicagoland
I wouldn't use the ball valve to throttle the output for the reason cobbler mentions. You will be restricting volume, not pressure.
If you were to install it on a T so the excess is discharged then I see no harm.
Not sure how well the typical ball valve will like 3000+ psi.
Have you investigated different tips?
YesIHaveAHammer
As I understand it, electronically variable pressure washers reduce the pump speed, and valve variable ones use a bypass/recirculation valve. Both methods also reduce flow volume.
Your ball valve would act as a restrictor, which is effectively what different nozzles do. A given washer module will have a range of acceptable nozzles - too small will make it work too hard, too big (or none) will make it run too fast. So your ball valve would need to be set corresponding within this range, which could probably be worked out by measuring volumes, but is a lot of hassle.
