King Nothing
- Joined
- Aug 7, 2016
- Messages
- 98
Hello. First post here. I have a craftsman pressure washer that is at least 10-12 years old but with little use on it. It has a Briggs intek 6.75 hp engine. I had to replace the pump due to leaving water in it and allowing it to freeze and went with an "inexpensive" ebay pump. The washer works great for the first 15 minutes after a cold start. After that, it dies when you let off the handle but works fine otherwise. After a few more minutes the pressure seems to drop off, then come back in cycles. I thought I may have hurt the engine by turning it upside down while changing the pump?
Sent from my LG-V500 using Tapatalk
