Pressure Washer Pump for Honda
lawfarm
NorCal
I have a ~10-12 year old Craftsman power washer with a Honda GCV190 vertical shaft engine on it. (The GCV is the homeowner series, plastic timing gears, etc.).
Engine runs like a top, and appears to have the 22.2mm shaft diameter. The pump burned up on me today, and is toast.
There appear to be quite a few manufacturers of similar pumps out there. Any recommendations on a suggested pump brand to try? While I'd love to upgrade to a larger unit, at this point the engine is running like a top and seems to have a lot more life left in it, so I'd rather just throw a new pump on it. This is one of your standard residential vertical-shaft pressure washers. There are probably 25 brands that show up in a search, so I’m hoping someone has a brand recommendation.
Alternatively, I posted this over on Pirate and everyone said I should just get a new unit with a triplex pump. While that sounds great and all, I can’t see the utility in wasting a good running engine—and triplex pumps won’t run on a vertical shaft. Thoughts?
yeldogt
My neighbor had the same type of unit -- there were two types of pumps. His was the cheaper type and he upgraded to the better style from a name brand company.
I think it was around $140 .. works better than new .. the engines run forever.
58Yeoman
Central IL
I bought a pressure washer for $25, as I wanted the frame/wheels for a project. The pump was also toast. The Honda engine ran great, and I sold it to a student at a university who wanted to tear it down and learn about it. He said that he wanted to work for Honda when he graduated.
ajbowman
I just bought a Troy-Bilt a couple weeks ago that had the GCV Honda engine on it. Bought it for $40 because it didn't make any pressure. Are you sure the pump is destroyed? Mine had an Annovi Reverberi pump, and I found a broken spring and fixed it for about $8. Works great now.
I was impressed with how rebuildable the AR pump was - I would recommend it.
CJM8515
Northern tool sells them, pick one they are all about the same.
L
lawfarm
NorCal
Yeah, I checked it out pretty thoroughly, as I've been able to just clean and rebuild the bypass cylinder before. Pump is shot.
earthmover1980
South West Michigan
The vertical shaft power washers use a 7/8 shaft. This is the same standard size as any Briggs and Stratton powered push mower. Buy a cheap replacement off of Amazon reading reviews to decide. There are few differences in the triplex styles. These are more of a throw away pump, inherently by the design(oiless). Amazon has em for $100 and less. Bolt pattern, and indexing of the inlet and outlets are the main difference.
The horizontal shaft power washers are a better design, and use crankcase oil that is serviceable. I sold my cheap vertical power washer and got a deal on a 4,000 psi 4gpm Honda one. The thing is super powerful, and glad I upgraded.
