Pressure washers
RMR&C
NW Montana
Looking to buy a gas powered pressure washer. Lower price range, yes, I know you get what you pay for. I can't afford the $1200 fancy ones right now...
Which one of the lower cost ones work the best?
Looking for actual user experience and reviews. Thanks
Fiberglass Fred
Texas
I was in a similar position 2wks ago.
I had a inexpensive ($200ish) gas powered washer for about 4 years. I used it a few times, probably no more than 20 hours. Last week, after fighting like crazy to get it to start, the pump exploded. I searched and searched and found that the replacement part/pump would have been about $120, but it wasn't available anymore.
There are $300-$400 models out there there that have more readily available replacement pumps, however those pumps are another $200. For that price you could just buy a new cheapie, with new motor too.
After all my searching, I replaced it with a $160 electric model that had almost as much psi. I'll still have to worry about the pump going out, but at least I won't have to worry as much about the motor needing attention (no clogged carburetor, from lack of use).
I used the new one all weekend. So far, I love it. Much quieter than the gas unit I had. According to the label, it has less psi (1800 vs 2200), but I can't tell the difference. If you want something cheap, I'd seriously consider an electric.
aojo
San Diego, CA
a couple of years ago I picked up a Sears/Craftsman pressure washer with a Honda motor/pump. It is used to clean concrete floors at a pub at least once a month and more often when there are promotions. It continues to start on the first pull and performs flawlessly. I think the value is the Honda motor which someone said is not used any longer but I dont know that for fact.
srmofo
SW ohio
kkcshipp
Generac at Lowes. You can read reviews from everywhere on the net. Took me two months of research to finalize my decision and it is made in the USA
R
RMR&C
NW Montana
I saw they get really good reviews.......way better than the comparable Craftsman units. Prices are right also, around $300. I'm going to look at the Generac's first...
Thanks for all of the input so far! Keep it coming. :)
nehog
Jaffrey, NH
I had a Craftsman and hated it. Would not start, would not stay running, leaked everywhere, leaked water, leaked gas, nozzles virtually impossible to change, surged constantly, and generally not very good quality. Had for about three years, and managed to get a couple of hours use out of it. Sold it for $35 at a yard sale last summer. Don't miss it at all.
I'm going to look at that Generac at Lowes next time I'm there. Gotta be better than what I had!!!
GRX
MD
Husky with Honda engine - 3,000psi, 2.5gpm. $299 on sale at Home Depot 4 years ago.
Numerous houses, sheds, detached garages, and stone patios over the last 4 years and it has worked flawlessly.
Silver Heels
I had a $250 "excell" from menards. Thought I was getting a good unit and bought it because of the honda motor. I put up with it for a couple of seasons, and when the pump went out, I danced a jig! It was the biggest POS. Even though it had a solid motor, it was loud, vibrated, and the starting procedure required depressing the handle on the spray wand otherwise the motor would bog down. I even exchanged it for another after using it only once, thinking it was faulty, but the next one was just as tempermental.
I did research on ones from Northern (nice, but a little spendy for non-professional use) looked at the Generac ( they don't use a name brand motor) the Craftsmans all seem like they are homeowner grade throw-away- when-something-breaks machines. You can tell by the pump. If it is an axial pump, it is not rebuildable and won't hold up in the long term. If it is a triplex pump, it is probably a machine that will last. Vertical shaft engines gernerally are mated to pumps that will fail in time
Ultimately, I settled on a 3000 PSI Dewalt from Home depot. At $550 it is double what a homeowner grade machine costs, but it has a commercial duty horizontal shaft Honda motor. I also learned that recently, the Dewalts changed from using very high quality CAT pumps to lesser quality pumps. The unit on display still had the CAT pump and so that is the one that I bought. I love using the machine, it is professional grade, should last a lifetime, and is fully rebuildable if you wear it out.
It is more expensive then a throwaway unit, but is much nicer to use, and I have not doubts that it would outlast many of the cheap ones. Don't be penny-wise and pound-foolish, get a good unit and you won't look back
bdamico
why not get an expensive one for the cost of a cheap one on craigslist?
GRX
MD
Try disconnecting the hose next time. Just as the instructions with mine said. ;)
some zilch
i bought a lower end "professional" generac model 2 years ago. it is very well made, and not department store garbage. it was $619, but has seen several hundred hours already and has never missed a beat
R
RMR&C
NW Montana
That would actually be my first choice....I have been watching for a good one for months. All I have seen were either junk or priced as new. Finally at the point of needing it now......
Silver Heels
I buy and sell a lot on craigslist, but pressure washers IMHO, are notorious for breaking, can be easily damaged by running without the water turned on or if allowed to freeze without winterizing. Plus most aren't built to last. I see many newer ones advertized for sale where the owners are up front about selling a broken unit for say, $50 because the motor is still good. The ones that work well never seem to be priced much less than new ($250 new, selling for 175 or 200) Just make sure you know what the price of a comperable new one is before you take a chance at a used one with an unknown history. Just my 2 cents.
Silver Heels
Mine actually said not to run without the water on. The better ones have unloaders that allow it to start without fumbling around with the hose or the wand
shannonw
Florida
Read up on the pumps if you can find the specs
A lot of those cheaper ones hd,etc you read up and see the pump itself has a 50 hour avg service life. I'm sure they slap a honda on them and that's what sells, no one ever thinks about the pump doing the work. Tons of ones on craigslist with crapped out pumps. I picked up a semi commercial one cheap for 70 and cleaned the carb. Not triaxial but the pump was much larger than the ones that mount underneath the motor and docs mention a service life of 800 hours.
That said though my old excel (bottom mount small axial pump) which i pretty much gave to neighbors years ago hours after it's first use so i didn't have to store the damn thing still runs and they pass it all over the neighborhood. Personally i never thought it was much better than a garden hose and brush..those cheapie axial home units but good for tight spaces. Newones though with the triax sound much better.
Even better though on the major stuff seriously consider hiring it out to a good company unless you don't have kids and/or loads of free time =) Big stuff i don't bother since i putzed around a weekend on an old stucco house knocking paint off, the better companies bring a truck mounted 25hp or something monster over and it'll strip the paint off a whole house in an hour while you spend your weekend doing something else and having a beer.
shannonw
Florida
Oh also on the home units, get one if you can with different nozzles, not the all in one wands...my all in one on the old neighborhood unit got clogged and i switched to the quick release nozzles and it was a noticeable difference in cleaning power (and it wasn't just from being clogged)....it had the same effect on an electric.
Also i never knew those smaller axial units were somewhat serviceable i never thought they were (at least on my 10 year old excel) but some neighbor ran it dry and burnt some seal or oring and my neighbor got it running for a couple of bucks, how i didn't bother finding out but he was apparently able to replace it. I mentioned 50 hour life but darn thing still runs after 10 years but for a home owner it probably is just hitting 50 hours now as you probably only use it a few hours or so a year so you can figure rough life expectancy.
Also be sure to keep em clean and blow em out, turn off the gas and give a couple cranks to get the water out of the pump and lines and silicone things down, they rust up like heck in a few years if you don't.
My guess is 2-300 gets you an axial 50 hour pump, get up in the 500-600 you'll be in a triax that is serviceable with much longer pump life (not that us as home owners really need it going by my old one).
greenlizard
Chapin, SC
My first washer was a Delta brand with a Honda motor. Got it at Northern Tools, IIRCC. As others have said, it is the Honda motor that attracts buyers. The pump was short lived. I then bought a new Snapper washer with B&S power from a local dealer. Dealer setup was poor, but the machine has given good service for four years thus far. I am careful to keep it in the garage during the cold months as icing in the pumps is supposed to be fatal. That may be what killed my Delta.
I can recommend the Snapper as well built and reliable.
crazytrain
Amish Country, Pa
I have an older Briggs and Stratton 3000 Psi. Never have any problems with it and only use it 2-3 times a year. You can change the nozzle for different power levels and spray patterns. I think it was like $250.00 at Home Depot or Lowes.
crewchief888
NW indiana
wife bought me a troy built 2700psi w/B&S last year for fathers day.
starts easy, no problems the 4 or 5 times i used it.
at least my stepdaughter dont have to hand wash the mud off my s-10 blazer any more :lol_hitti
:beer:
