PharaohXJ
Don't worry I'll post it up each time on here
grip lime green socket tray $20:
http://www.princessauto.com/en/detail/80-pc-socket-holder-rack/A-p8674095e
very similar to kobalt but they charge $40:
https://www.lowes.ca/tool-boxes/kob...age-tray_g1185208.html?searchTerm=socket-tray
I have a kobalt one, can arrange in any fashion you want
More pegs can be bought at princessauto:
http://www.princessauto.com/en/detail/3-8-in-dr-nylon-composite-socket-rail/A-p8341729e
$15 each:
http://www.princessauto.com/en/detail/6-pc-sae-impact-power-nut-driver-set/A-p8377079e
http://www.princessauto.com/en/detail/6-pc-metric-impact-power-nut-driver-set/A-p8377087e
Yeah but the princess auto rail pegs don't fit......
Did you try?
Found this to be very handy to have in the shop
http://www.princessauto.com/en/detail/24-in-aluminum-caliper/A-p8523912e
Were they in store as well or only online?
Got my new Dannmar lift installed. When I built the garage I was figuring on a symmetric lift. I ended up purchasing the asymmetric Dannmar 10ACX from Princess Auto. Easy to install and it works great. I have also attached a picture of the frame cradle pads I built. The factory ones were too expensive.
3 pc titan ratchet set $60
How do you like those
I have a few 36 tooth Williams that are work horses. Those titans being as long as they are, the end of the handle will have to move a mile before each tooth click. I'm sure they gave them 36 teeth for strength because of their leverage.
This makes a lot of sense to me. I can't find a link to back up my opinion but, less teeth = more strength and contact area, that's how I've always understood it
All I know is that higher splined axle shafts in a rear end are stronger than lower splines for the same axle diameter
When it comes to ratchets. There is also the factor of multiple pawl design which almost doubles the number of engaged teeth vs a single pawl
You could also compare fine vs coarse threads where fine is stronger.
I counted 9 teeth on each pawl that is 18 out of 168
More than one tooth there
Looks good. I'll pick one up when they go on sale.
Yeah I'd like the 1/4 and 1/2" to add to the collection
This one is on my list as well. 72 teeth and almost a foot long. Very handy for under hood import work.
http://www.princessauto.com/en/deta...sionid=76WfWRDYpupBpM5Br9+wMn14.pal-prod-com2
