Pro Lighting LED High Bays
gogolf0401
West central MN
Anyone here tried these LED high bays from Pro Lighting?
B4146SSUMXX-HO5K
Was thinking of getting 9 of these for my ~56x40 space with 14' sidewall scissor truss 16.5 peak. Overkill?
Any reason to stay away from these types of lights?
American Locomotive
Rhode Island
I mean it doesn't seem like a bad deal, but these "pre-gutted" fluorescent fixtures pre-fitted with retrofit tubes always came off as a bit cheesy.
As far as being overkill? Not even close. That's only 140,000 lumens over 2,000 square feet. Don't get me wrong, it will be tons of light, but you could realistically add another 6-9 fixtures and you'd probably still be under 100 fc light intensity.
cybrdyke
USA
Techbrite makes good stuff. Made in America, too. But it's still just an empty chassis with 6 LED bypass tubes. About $100 in value.
CD
G
gogolf0401
West central MN
So do you guys think this is the better way to go then, given the higher cost?
PL150HB5KLED
I kinda like the idea of being able to replace a LED tube if one goes bad as opposed to an entire fixture. Maybe I don't need to worry about the failure rate of these.
cory58
Charlotte, NC
CD
Just went to the Techbrite web site. Couldn't find a mention of made in the USA. Maybe I just missed it.
Also, looks like all of their high bays have ballasts. To me, part of the appeal of LED high bays is no ballast. One less failure point that would require me to rent a lift for repairs.
Not knocking Techbrite. Just still doing research for lighting my new garage and appreciate feedback from people who know more than me.
Cory
yeldogt
I would purchase one before committing. Like many of the consumer T5 fluorescent fixtures -- the light from many of these entry level LED's is too centralized / harsh.
cybrdyke
USA
Cory
Hey Cory,
Here's their spec sheet for the highbay with no ballast. Made in Cincinnati, USA.
http://techbrite.com/pdf/d8b7042b-806c-4ead-ab9b-25e8cc29774c.pdf
They also make them with ballasts for those that want to use that kind of LED tube.
You're never gonna get rid of ballasts. LED's still use them, just called drivers. An LED fixture that uses light strips instead of tubes will have a driver. No-ballast LED tubes still have a driver, it's just hidden inside the tube.
Good luck,
CD
cory58
Charlotte, NC
Hey Cory,
Good luck,
CD
Thanks CD! Made in USA would be great. I should have been more specific in my post - external ballasts.
Was not previously considering any high bays with separate tubes. Everything I've been looking at has the LEDs integrated. So much information, so many choices....
