Got this set at a pawnshop the other day and when I was trying to use the ratchet, the pawl would not stay engaged to the gear when I go to ratchet the socket. There is a lot of forward to back play in the lever and the T8 screw that holds the lever into the pawl is stripped. I assume someone has messed with it before. The lever never really stays on or off. It is sort of loose and stays between on and off when you try and ratchet the socket. If I keep pressure on the lever, it feels like a ratchet should. I thought these things are just like normal ratchets when you use the adapter. Does anyone have any idea what could be going on? Here are a couple of pictures to show the condition of the ratchet, pawl, and adapter gear. I can provide more pictures if they are needed.
<a href="http://picasaweb.google.com/lh/photo/_HGcHrvfhMX45nvDw5h9Wq_dcUmG5KSpcSPlU_GDsKk?feat=embedwebsite"><img src="http://lh5.ggpht.com/_uzc6PkbBIR0/S-tGNHNtGsI/AAAAAAAAARs/zPOk9RmQZsk/s800/IMG_3197.JPG" /></a>
<a href="http://picasaweb.google.com/lh/photo/AMu3Kj9V73acPC6PQoRbfa_dcUmG5KSpcSPlU_GDsKk?feat=embedwebsite"><img src="http://lh3.ggpht.com/_uzc6PkbBIR0/S-tGIJrPxNI/AAAAAAAAARo/bPlHNHDkRkg/s800/IMG_3196.JPG" /></a>
<a href="http://picasaweb.google.com/lh/photo/kozT6NjSmfxSpPOQ9idiIK_dcUmG5KSpcSPlU_GDsKk?feat=embedwebsite"><img src="http://lh6.ggpht.com/_uzc6PkbBIR0/S-tGF7yf0XI/AAAAAAAAARk/fgKxfgFVgio/s800/IMG_3195.JPG" /></a>
<a href="http://picasaweb.google.com/lh/photo/z-fyg4sbE0doy38ACEPqVK_dcUmG5KSpcSPlU_GDsKk?feat=embedwebsite"><img src="http://lh3.ggpht.com/_uzc6PkbBIR0/S-tGO9aEiVI/AAAAAAAAARw/JxHrTh71O-o/s800/IMG_3198.JPG" /></a>
<a href="http://picasaweb.google.com/lh/photo/AgRTb6P16dWyCw0yTgvWmq_dcUmG5KSpcSPlU_GDsKk?feat=embedwebsite"><img src="http://lh5.ggpht.com/_uzc6PkbBIR0/S-tGQ5VyglI/AAAAAAAAAR0/ofA9WQ3PqUM/s800/IMG_3199.JPG" /></a>
In that picture is the selector all the way to one side, or simply in the middle, or you don't know?
