automotive stud
I bought a pretty decent looking media blaster online like this one:
http://www.homedepot.com/Outdoors-O...splay?langId=-1&storeId=10051&catalogId=10053
I've seen the same one at Harbor Freight, Northern Tool, ect... it looked pretty decent for the price so I ordered one.
Hooked it up today and the pressure seems really low at the nozzle even with 120psi in the tank being fed from my 60 gallon compressor. I went to blast an old tool box with Aluminum Oxide abrasive. I kept having a problem with it only blowing air and no media. Is there anything I should check? The directions are pretty crappy, I assume all of the valves should be open, there is one on the bottom of the tank to feed the media and another that just feeds air into the gun. I even tried shutting that off so I only had the pressurized media but it still worked on and off. Even when it did work it could barely blow a hole through a wet tissue never mind remove paint.
I should have known what I was in for when I went to put the cap on and the bar hit the handles. I had to cut a half inch off the bar on the cap just to take it on and off.
Any tips??
Any tips??
