Problem with the Milwaukee 2460 rotary tool
Is it the collet or do I have a bad mandrel ? The collet will not clamp down on the mandrel with sufficient force for me to tighten/loosen the screw that holds the fiber disk use for cutting small (<1/4") bolts !
Anyone else have this problem ? Solution ?
(Old Dremel tool works fine with that mandrel, but that collet will not fit into the 2460 !)
ChevyEFI
Phoenix, AZ
Mine is < 1yr old, but I haven't had any problems with the Milwaukee collet / collet nut.
It seems everyone solves the problem with Dremel brand pieces.
Also, perhaps an M18 Fuel Surge impact driver would help loosen the screw. j/k.
signcrafter
Have you measured the diameter of the shank of the mandrel with a caliper or micrometer? When you take the collet out of the tool and slide it on the shank of mandrel is there play or is it a pretty tight fit and just barely slides along the shaft?
cmandp
New Jersey
I feel like my rotary tool came with a second collet, could you try that?
But I bought a dremel chuck almost immediately for my Milwaukee. Way easier and I can use tools or drill bits that aren't 1/8" shank.
2manytools
Mt Pleasant, MI
I bought one of those on eBay but turned out to have the wrong threads, but seems very convenient. Do you remember what size you bought?
Zapp Branigan
I bought the same Dremel brand collet. All the Dremel stuff is direct fit, including the cable shaft.
T
The fit seems "right". Not loose.
I bought the same Dremel brand collet. All the Dremel stuff is direct fit, ...
This is the issue ! I swapped the mandrel and cutting disc from my Dremel to my Milwaukee. It needed a new fiber cutting disc and the collet would NOT tighten down enough to unscrew the mounting screw. I placed it back in the Dremel, and the collet locked down sufficiently to get the job done. Then I tried to put the genuine Dremel collet in the Milwaukee and it would only go half way in.
I will have to get out my calipers and check the OD of the mandrel and the OD of both collets.
Crazyjake8493
Upstate NY
The Milwaukee accessories are absolute junk. I chucked mine and used a Dremel mandrel and collet and have had zero issues.
I initially tried the Milwaukee mandrel and collet without a cutting disc on it, and it wobbled so bad it bent the mandrel. I thought the tool was defective. Put some extra Dremel accessories on it and the thing is perfect.
T
The OD of the Milwaukee collet is 4.26 mm at the base. The Dremel is 4.31mm.
As I said, I tried to put the genuine Dremel collet in the Milwaukee and it would only go half way in. How did you get it to go in ?
ChevyEFI
Phoenix, AZ
Since I killed my dremel last week and my Milwaukee cordless this week, please report back on the fix you employ. :D
T
I broke out the Milwaukee again today. If you REALLY cranky down on the collet nut it seemed to hold the mandrel adequately.
I frequently use oversized mandrels and cutting disk. They have a certain speed where they vibrate excessively. Above or below and your fine.
ChevyEFI
Phoenix, AZ
Update: My Milwaukee is back as a new replacement.
It came to me with no collet, but the collet nut is, like the rest of it, new. Since the one I sent in was cracked and in pieces, I guess I get what I get. :lol_hitti
Do these have brushes inside? Curious.
