Project Farm Floor Jack comparison - Mighty Snap-On vs Harbor Freight
m6z
Missouri
Man, lots of back and forth over a floor jack. Hell, even at the current $300 price I think I'd pass and go with the $150 option. I'm currently using the Pittsburg 1.5T aluminum jack. I've had it several years now, for $60 it's been pretty great.
Hiball
Missery
Is it possible to swap the two different seal kits?
Are they interchangable in anyway?
No, the Pump pistons are machined to accept Orings, versus a Piston style Ucup on the lower tiered Daytonas. The Main ram piston seal that accepts the Oring/retainer is different than the one that accepts a Poly U/Ycup.
tarbellb
Oregon
Thanks Hiball
Im not familiar with the build of these, could you swap the entire piston out?
Hiball
Missery
Thanks Hiball
If memory serves, The cylinder bores are in fact the same, or where on the two Daytonas I compared. I can’t speak across all models that share this hydro unit. If you want U/Y cups all around, move away from the Daytona line and into Torin, Northern tool or Menards model that cross references to premium seals.
Steve_P
In regards to the Hydraulic unit, as I’ve stated numerous times is nothing New. The HF line itself covers the lower tier units all the way up to the super duty. We aren’t talking big manufacturing setup/testing swings as the core unit will accept the variation that the customer is requesting (gland versus piston). It was similar on the previous single pump quick lift jacks in regards to seal components.
I purchased the HF Superduty when it first came out, I was curious to the internals and what made it tick inside. I was really surprised to see them cheap out on the Ram seal, especially since they advertised premium seals and utilized Ucups on the pump pistons. The move in my mind was strictly a attempt to control the lifespan of the jack. When you are talking Pennies in regards to the seal itself and option for a ram to accept a Ucup versus the shell/Oring already existed across the board it’s hard for me to believe otherwise. I get it.. HF is in the business of bringing new flashy brands to the table and excitement to the marketplace. I don’t hate them for it, but the Daytona line will eventually fade and whatever there marketing team comes up with take over and Rinse and repeat.
I’ve said it before and I’ll say it again, the HF superduty with its 3 year warranty is solid jack. It doesn’t check all the boxes of being a jack that will likely be rebuilt numerous times over the course of one’s lifetime. I say this because the hydraulic unit doesn’t like to be disassembled, even with a proper sized socket the tank nut was coming part in chunks when removed. The pump cylinders are thin in comparison to previous “professional” jacks that I grew up with, but if I’m being honest. The current marketplace and end users have very little interest in rebuilding a floor jack, The excitement of whatever marketing campaign is being pushed, long exceeds fixing what’s broken.
The entire “1” factory making all Chinese floor jacks is flawed, the major players of Tongrun, Shinn fu and dozens I’m probably forgetting or unaware of, are flanked by 100’s of available factories ready to take your order simply by doing a quick google search. Do you want Ucups all around? Buy a Torin or yellow jacket from Northern tool. Do we want to design Garage Journal model? Who is in? I suspect it would be cost prohibitive and make SO’s model look like a bargain.. Ha
For me, this sums it up. I've had ~10 HF jacks, floor and bottle, and they've all failed within 10-15 years. Because they refuse to use u-cup seals everywhere possible. They use o-rings to save a nickel and this ensures produce obsolesce over time; that's the only justification. Everyone raves how great the HF jacks are, and they are great for the first few years, but in 10 years, we'll see how these are holding up. Every one I've had has failed: leaked, leaked down... I've given up on HF jacks. Yes, the cost vs life in comparison to a HW probably makes sense, but I'm done participating in their 10 year homeowner lifespan game and have gone to HW and AC.
ajchien
Los Angeles, stuck on the 60 freeway.
I consider you lucky. I had three “less expensive” floor jacks (~$100 range) about 10-15 years ago. They lasted me 6 months (HF), 12 months (Larin), and 13 months (Duralast) before leaking out.
The HF one was Torin made which I took apart a few times to replace seals, which never quite lasted because … the pump piston wasn’t cylindrical, it was bent … and grooves that were machined to hold o ring seals still had sharp burrs on them. These things were clearly seen by the naked eye, so whomever was in charge of QC for that jack obviously saw it and still allowed it to get packaged and shipped. I know some people laugh at the concept of labeling a product “assembled in USA”, but I would hope that if a company prints that type of nationalistic pride on their product, that their QC process wouldn’t accept bent pistons or left over machining burrs.
Mr_B
Reading
To be fair o-rings can do well, i still got some jacks from 70's & late 80's that still function good on o-rings but the internal manufacturing finish and o-ring grade was proper effort .
u-cup/y-rings are safer and likely longer life bet mixed with lower effort lower QC mass production .
A tyre shop near me went through the Daytona fad, did get warranty on at least one that I know of, pool of oil out the pumps was what happened, had one ram fail and they had the car on 2 jacks only with front wheels off for tyre fitting, that customer car hit the floor and he went off Daytona, for sure he should of had stands but it not uncommon see lot of tyre guys use jacks only even a 3 jack 4 wheel removal gamble !ol .
Pre economy collapse it was a 170buck jack :-/ I see in UK they can get the Yellow Jacket version still for that money and shipped mainland free,that retail price in today's economy kind of highlights the manufacture effort in them at this production level ...
This pretty much nails big part of the reality why better jack is more money, It more than just paint and stickers difference, you can be pretty sure internal finishing choices and the QC will be some level ahead , Snap-On jack from what I recall never proven to be same factory as HF and even if it was the internal finish could be far different process or even final finishing/some parts and assembly done by separate manufacturing partner .
The legal case only helped highlight the claims the Daytona same as the Snap-On, HF picked up on usefulness of youtube too and they been feeding the shills to some success although tool reviews seems burned itself out to some extent thankfully .
Daytona was a miracle of advertisement input and modern social media and not so much Engineering input & modern manufacture .
One thing HF can beat Snap-On at is legal games and advertising ...
G
General Geoff
Allentown, Pennsylvania
IF my HF Daytona ever gives up, I will probably replace with the Northern Tool Yellowjacket which advertises Y-rings over O-rings
Polyurethane Y-rings provide a more secure seal than standard O-rings to help extend jack life
In my area the HF Daytona has completely taken over. I see them at a friends manufacturing employer, at the local oil change places, at the dealerships and at most of the private shops.
They use them, then they leak or do not lift, then they are thrown in the dumpster and they get more of them.
Jtels85
The guys at the shop make fun of SnapOn. Overpriced, poor service and they can get better tools for less money. That’s why they use Daytona jacks.
2ndGearRubber
Pittsburgh
Without a good dealer snap on is a tough sell. The infinite backorder on everything doesn't help either. Folks need to put in some OT to get my cart accessories done.
Mr_B
Reading
why limit the choice to Daytona or snapon, throw in extra 50 bucks over a Daytona and you get better construction/seal versions, double the price and you into Hein Werner or preferably AC Hydraulics options .
Niether the Daytona or the Snapon a great option, Daytona was hard complain when under 150 bucks as DIY it good enough & value and trade would take the gamble, at 300 buck price range it not such a disposable price and from profesional standpoint if are using it every hour of the day it won't be best choice over time .
qqzj
Looks like snap on exists mainly to justify Daytona as a good deal. Nobody, figuratively speaking, actually view it as a serious option
Mr_B
Reading
I guess, the real world price for the snapon isn't 1200 bucks but it is far from good option or good use of dollar .
zendriver
Indiana
Daytona Jack - 3 ton currently on sale $150 bucks. If something more expansive is a better deal or more desirable, go for it.
I used what is probably the first 3 ton model floor jack, HJ ever sold yesterday, still works fine. I think I paid about $80 probably 12 years ago.
2ndGearRubber
Pittsburgh
This is the inherent issue of "X vs Y" with a larger price spread.
IMO its much more interesting to compare the meaty middle area to define what value exists and various tiers. For instance with ratchets you go from 9.99 to over 100 for a 3/8 ratchet and those are the main areas people want to discuss. What about the 20 dollar option? Or the 80?
Full disclosure, I helped my father carry out a steel HF jack about 20 years ago. SOB was heavy for my little arms, but I did it. I'd spend any amount of money to save that jack, but not because it's the best unit ever made.
dchawk81
How old were you 20 years ago?
f121
UK
I really like mine. Great jack and I’ve got a lot more confidence that I’ll be able to get parts for it in 5-10 years time.
