Kevin54
MEMBER EMERITUS
How warm is it to be digging without a shirt? It looks like I still see some snow in the background of some of the pics.
Sheesh, and no warning?
I thought we were suppose to be a team on this site.
Ditch digging is good exercize... And the punishment fit the crime(mistake?).
I'm completely unfamilar with wood basements so I thought maybe you knew something I didn't. Sorry, I should have spoken up and atleast asked about it.
Scheduled now for next Wednesday...
Whew, hate to say it... Lots!
I will say, we do plan to be moved in before the snow flies, but nothing is certain so, worst case, for the good of the house we need:
-Locked in: As far is it goes, we have 3 windows left to put in and hopefully replace the rear door that will lead to the deck (this door is not an exterior door and need's to be replaced badly). So as it goes, we are really not far from lock up.
-Electric: The electrician is booked for the first week of September to upgrade our house with a new panel and run the service for the power, but we are on a waiting list for our service provider (SaskPower) to come and upgrade the service to the property. We don't know when they will be coming but it should be well before freeze up. I suspect and hope that the electrical will be complete before the end of September.
-Insulation: I hope to spray foam the basement with 2" and will insulate the rest with batts, porch will just be batted.
-Furnace: I suspect the house would hold up much better being heated rather than not being heated.
-Basement floor: I'm tossing back and forth from doing a concrete floor or wood. Wood would be cheaper and Concrete would be faster. It's a catch. But do to the load on the walls from the earth I'm leaning towards concrete for the strength factor and the time it would save us. We need a floor in before the earth freezes so that the walls are supported from the ground conditions. Kicker is we need to get the septic installed before we can put the floor in.
-Siding: Although I don't believe it would make or break anything one way or the other, it would be best if the exterior of the house was completed just to prevent the weather from getting in. Building wrap by itself does go a long way but doesn't last very long in the direct elements. I'd also rather be done this part before winter sets in.
Off the top of my head this is all we need worst case to protect our home, I don't forsee any issues getting all this done, of course though, to get living in it we also need to put together our plumbing, water system, etc.
Right now half the battle is priorities. It's +30 C today and has been beautiful all week but it's easy to forget that the nice weather is on it's way out. Focus is needed to make sure that what's needed is in before freeze up and it's a small bit of a balancing act figuring out what can be reasonably left off until we move in all the while not wanting to leave off all the finishing to burden us when we live there, it's one thing to have small indoor projects over the winter but ongoing complete construction is another... It would also be nice to knock off complete areas from the to-do list, because as I'm sure you can tell right now there is something to be done everywhere I look!
But as close as winter is, the real freeze up is 3-4 months away (hopefully). A lot can be done in that time and I'm interested to see where we stand come Christmas. (Hopefully we won't be standing, but sitting in our house enjoying a spiked hot chocolate)
Seriously, though, put it at the end opposite. In doing so, the main house will be warmer and the bedrooms cooler. And if you pour one pad for now, you can get the furnace set, ducts ran, and the flue ran. If you don't have a 95% fuel efficient furnace minimum, then I don't think you can run the flue out the wall. I could be wrong as they change things all of the time. But if you have a flue that has to go up through the roof, you may have to locate the furnace under a closet so the duct will be hidden.
