propane heater in work space.
a52-830
north of boston, massachusetts
i am sure this has been gone over before, but finding it is more work than i can stand today.
my work area is in part of a metal storage building. i bought a huge tarp, and have draped it at the back of my area, since i dont want to heat the other two thirds of the space.
i have one of those cylindrical floor forced hot air proper heaters, but they are not meant to use in an enclosed space. i understand that the primary waste gasses are carbon dioxide and water.
since i assume that at least some of you use these things to heat an enclosed, but not tight, space, i was wondering if there are any recommendations for detectors? carbon monoxide detectors are common, but i want one that will specifically cover dioxide also.
your recommendations on detectors are appreciated.
I heat my uninsulated garage with a double burner tank top heater. I only run it for a 2-3 hours at a time. It only get the work area up to about 50F. If I was going to run it longer, like 8 hours, I would probably get a CO detector.
Marcm157
Newburgh, NY
I have been using the same type heater in my 1100 sq/ft garage / shop for the past 2 years. I run it for about an hour or so then shut it down. It heats the place very well and my Carbon Monoxide detector doesn't even move off zero.
I just scored a brand new ceiling mounted Reznor gas heater from work so I will be switching over to that going forward but other than the fumes from the propane heater and the fact that it drank gas it did the job for me...
laser3kw
northen IL
I use the same type in my insulated 1200 sq ft. I burn for for hours at a time. My Carbon Monoxide detector rarely moves off 0.
laser3kw
northen IL
I did leave the garage door open a crack, probably could leave screen in man door open for same effect. CO detector seems like a good idea.
get one with a display / readout. I find that handy to monitor actual level instead of waiting for it to go off.
The Cobbler
I'm temporarily using (until I get my MOdine nat gas heater installed) the tank top radiant heaters. not meant for indoor space but I have some air leaks and a CO detector . no problems yet. I wouldn't want to heat that way on an ongoing basis, but for temp heat, I'm comfortable
