Garage Flooring
Products like Swisstrax, TrueLock Plus, RaceDeck and Sport Court use quality raw materials that yield great results. There is a ton of information out there about Chemical Resistance etc. Those of us in the industry like to make things sound fancier and more complex than they are. If there are specific chemicals that your floor will be exposed to on a regular basis, get a couple of samples in the color you intend to use and test them out. In over a decade in this business I have seen some incredible things, but the irony is in the end its a plastic tile designed for the garage floor. It won't cure cancer, won't span floor joists on 12" centers and if you stick a blow torch to it its going to melt
The key to any flooring product is to decide what you want it to do and test is for that particular application.
You also have to keep in mind that industry testing standards are not necessarily done with the consumer in mind. I used to be a regional manager for a metal roofing manufacturer. We sold products with Class 4 hail ratings. It was published on every brochure and bragged about by many of the salespeople. The problem with that test is your roof can look like it got beat to death with a hammer, and if noting penetrated the rating stood -- and in some cases insurance would not pay because the roof was in tact. Polypropylene tiles, within each 12"x12" square are very resistant to a lot of things. BUT if the goal is truly to protect the substrate, they are not the right product.
All of us in this industry are salespeople. Most of us love what we do and what we sell and most of us do an honest job selling it. BUT be realistic about what is being purchased and run some tests of your own.
The key to any flooring product is to decide what you want it to do and test is for that particular application. You also have to keep in mind that industry testing standards are not necessarily done with the consumer in mind. I used to be a regional manager for a metal roofing manufacturer. We sold products with Class 4 hail ratings. It was published on every brochure and bragged about by many of the salespeople. The problem with that test is your roof can look like it got beat to death with a hammer, and if noting penetrated the rating stood -- and in some cases insurance would not pay because the roof was in tact. Polypropylene tiles, within each 12"x12" square are very resistant to a lot of things. BUT if the goal is truly to protect the substrate, they are not the right product.
I was thinking more about the chemical resistance of the different tile floors. I found the following PDF from Race Deck stating their tiles are 100% polypropylene.
http://www.joewilde.com/files/products/garage-screens/RaceDeck-FAQ.pdf
Being in the environmental business for awhile, I understand that different materials such as polypropylene (PP), high density polyethylene (HDPE), polyvinyl chloride (PVC), etc all have different chemical resistances. Truthfully I understand HDPE the best as that is 99% of what we sold and installed. When speaking about those type of liners or custom fabricated structures (sumps, manholes, etc) the real concern for contaminate leakage is at seams. For the most part, these liners are considered "leak proof". However, leak proof is typically defined by a small acceptable amount of leakage after a certain period of time.
I suspect PP is the same. Therefore, I found a chemical resistance chart to give me an idea how resistant to chemicals the RD tiles should be. Below is a link to the data I found:
http://www.gilsoneng.com/reference/ChemRes.pdf
Using my previous "spilled oil example", I decided to check on petroleum since that is the major content of motor oil and probably the most likely to be dropped on a garage floor. Look on page 20 of the attached link, and we can quickly see that PP has a good chemical resistance of petroleum up to 68 degrees. At 104 and 140 F the grade goes down to a 2 (limited resistance). There is no rating at 141+ F.
Other chemicals can be cross referenced. This is the one I chose to analyze.
So to me it looks like the solid tiles should offer some protection to the floors underneath, with the mindset each joint would be your weak point. While I mention Race Deck in this analysis, this would be true with any tile manufacturer of PP material. It's the properties of PP we are comparing.
Anyhow, not sure if this will benefit others, but I found it interesting.
