Protecting generator from rain/snow during use
Mainiac Mat
Maine
Hey gang,
I finally got sick of fiddling with and babysitting my fickle 29 y.o. Coleman 5KW (peak) generator every time we lose power and upgraded to a new Champion 9KW (peak), open frame, Tri-Fuel, electric start, invertor generator.
For now, I'll keep connecting to the house via. a 30 amp, 220v, 6 circuit GenTran box with a twist lock plug, but I ordered a 40 gal. LPG tank and plan on mounting it to an old Harbor Freight mover's dolly, and hope to avoid ever putting any gas in the new genny.
The idea is to be able to run >12 hours continuously without fiddling with the generator. But in doing so, I'd prefer to not have the generator sitting in the pouring rain or snow.
So my question to the forum is, how do you keep the rain and snow off your genny while it's running?
Ideas so far are to:
  • make a bracket to mount an oversized golfer's umbrella to the generator frame.
  • make an vented/open sided "doghouse" with a pallet base and move it around with my tractor forks.
  • zip tie a plastic panel over the top of the generator fuel tank
Renegade1LI
long island ny
It’s a pallet base and add 4 posts high enough for good air flow and a metal roof. Easy to pick up and move and cheap to construct.
redmondjp
Redmond, WA
I'm working on the non-inverter model of that Champion generator now, with about 15 hours of use on it (is probably 2-3 years old now). Whatever you do, keep the sides open for cooling. Despite a clean carburetor, on fresh gasoline it lopes with only 3KW of load on it, which smooths out when you partially close the choke (main jet is way too lean). It doesn't run on LP at all any longer, which is why I am working on it. From what I can tell, the Chinesium demand regulator no longer functions. I am probably going to install a Garretson KN style regulator on it with an adjustable load block and hopefully that will work. Oh, also, get rid of the crappy OEM Chinese spark plug ASAP - it will look fine but just throw it away and put a better one in (I usually use NGK). Personally, I think the power levels printed on the side are much the same as lawn mower, vacuum cleaner, and air compressor HP figures were in the 1990s and 2000s - very optimistic! Good luck with yours.
Jgaz
I used to keep my Honda under (and chained to) a cast metal patio table on the patio at the rear of my house. Plenty of air flow and protected from the weather.
mike93lx
Richmond, VA
I always kept mine close enough to the house that the overhang kept it mostly dry. Otherwise, maybe an inexpensive patio umbrella could worlz (of not too windy) or even just a piece of PT ply on top
Mikeske
Washington State
I just roll my over from my shop and it stop when I am in the carport. Protected and dry the entire time I need it. I put it in the same area as my barbecue IMG_7250.jpeg
Dig Doug
Build an open sided or 3 sided ( for sound reduction) dog house where you want to use it, face the exhaust out away from the house.
GrayFlattop
Chicago
I’d go with a small pop-up canopy tent. You can probably find an 8 x 8 for around $50. They come in handy for lots of things. I used to bring one to driving events for shelter from the hot sun or pouring rain.
sofasurfer
Good topic. I have never worried about it so far (snow never accumulates on it)but now you have me looking around for ideas.
Heres a couple from Amazon (search "portable generator protector")
sofasurfer
For use when operating I think I'll make a simple pvc frame with a tarp that clamps to the generator frame.
larry4406
Northern Virginia
PatY
WNY
I keep my Coleman in the garage when not in use but whenever I've needed it, usually storm related I just put it out in the driveway next to the house unsheltered. Never had an issue in snow or rain.
charbar
Midwest
My old man cut the side out of a 275 gallon IBC tote for his generator. They are designed to be lifted with pallet forks. If you are around a farming area they are everywhere and you can usually get one for free or 10-20 bucks at the most.
TurnipTruck
Southcentral Alaska
A friend of mine thought his Depot special generator failed and had to buy or borrow a replacement in the middle of a multi-day outage in a panic during a blizzard$$$. He later discovered the air filter had completely packed off with snow.
He now has a Cummins brand nat gas standby generator in an attached enclosure with an airtight upwind wall.
The enclosure also has plenty of room around the genny for maintenance, lifting eyes above the heavy stuff, chain link fencing over the air vents, and multiple lights inside. Complete and total overkill, but his wife will never get cold again.
