PTAC questions
dshop
location Raleigh NC/
a little off subject, but I have a 15x12 sunroom with double pane insulated window walls, spray foam insulated floor and ceiling.
Currently I have a 10k LG 110v thru the wall AC unit which seems to do not much.
I have the power to put in a 240v PTAC unit rated at 12k which would help me in the colder weather as well.
My question is...would the PTAC make any difference? I could go with a 16k PTAC or even an 18k unit.
thank you for your replies.
zmaxmotorsports
South of omaha
That small of an area shouldnt take much to cool,Have you tried removing the window ac and cleaning both coils out?
I usually reccomend removing the covers to get access to both sides of coils.
Ohmthis
Outside of Louisville KY
Zmax is right on. Also check and clean the filter frequently. I have to clean my inlaws PTAC coils twice a year. They have a couple of cats that love to hang out in their sun room.
Big Daddy Chop Shop
Hope, Indiana
One of the downsides of PTACs and Mini-splits is the filtration is ****. Washable screens are not really all that great for filtering air. If you have a 20x20x2 pleated filter and stretch it out, there is a TON of surface area there. Yet, a PTAC or Mini-split of the same tonnage will try to run all the air thru a 10x20 flat screen.
Long story short, pull it (easy to do, so that is a plus) and clean the inside and outside coils. Wash them the opposite of the airflow to get the junk out.
if the unit is functioning even 1/2 way right you should have a plenty of capacity.
