Puget Dude’s creations and fabrications (Random project thread.)
Bob Heine
Boca Raton, Florida
Bob, agree with you on Wen. I also bought a couple of their rotary tools. I am done with overpriced junk from Dremel, now have three with broken collet locks and one with a bad switch. Paid about $12 each for the Wens, haven't killed the first one yet, the second one is still in the box.
I am really a fan of the Milwaukee M12 die grinders, especially the right angle version. It's important to note that when you weld like I do you own every type of grinder and sander ever made. I have been watching for a M12 bandfile to go on sale, finally pulled the trigger on one at $223 last night.
Scott, I have both the straight and angle M12 die grinders and wonder why I waited. I'm also the proud owner of a Milwaukee M12 6-inch HATCHET pruning saw I found for $136. I'm thinking I can replace the chain with a belt and....
Never mind, I'm just going to wait for someone to get tired of their M12 bandfile and pick it up for a [more] reasonable price.
P
PugetDude
Superstition Mountains, AZ
Depends on the load, length of time, etc.
But a rule of thumb seems to be a charge usually lasts longer than it takes a second battery to recharge. I have 15-20 M12 tools, so quite a few batteries and a couple of chargers, can't recall ever waiting for a battery to charge. I seldom grab it and use it continuously until a battery is dead, so your question is difficult to answer. It's more than sufficient for how I use it.
I use a Bosch corded 4.5" grinder for bigger stuff or extended use, but the 2" grinder is great for detail work, prepping weld joints, tight spaces, etc.
Jgaz
Thank you sir! It sounds as if it would work well for me.
As of now, I’m waiting on my compressor to “catch up” a lot of the time but it’s really not too bad.
I really don’t see myself investing in a larger compressor and air plumbing system like I sold with my last house in Michigan.
BTW: I‘d like to say how impressed I am with the projects you have shown in this thread.
The combination of imagination, artistic flair, and execution are fantastic.
My wife loves your house number marker and a buddy of mine in Michigan is currently sourcing license plates for his own flag.
The locker to gas pump idea is one of the coolest things I’ve seen on here yet.
Thanks for posting
P
PugetDude
Working on a little welding project; had to open up these mounting tabs from 1.12" inside to 1.68" and maintain the hole orientation for the mounting bolts.
Decided it was simpler to just bandsaw one of the tabs off and fab a replacement. Used an old 3/8 carriage bolt and three nuts to set the width and verify the hole to hole registration. Crude but effective.
Before:
I really like this little Veritas square, it's about the size of my thumbnail but really comes in handy for jobs like this.
After:
More tomorrow.
P
PugetDude
Needed a clevis end for push-pull cable.
Decided I could make one quicker than driving across town to buy it.
Bandsawed out of a piece of scrap 3/8" aluminum with the Portaband table , 3/16 through hole on my 40 year old Grizzly drill press, end drilled and tapped 10-32 for the cable end. Rounded the edges on the 2x72 belt grinder.
Took longer to lay out than it did to fabricate.
P
PugetDude
Well, looks like I need to post a few pics of my latest project... been working on it for a couple of weeks but wanted to make sure it was actually going to be feasible before I posted pics here.
This followed me home recently, first item of business was to get it cleaned up...
Had to make lifting eyes for it, fabbed them out of some 1/4" aluminum scrap.
Then see if it was it was going to fit... it does, but not a lot of room to spare. It does fill the space nicely, have a bit of an issue with the steering box, but I can make it work if I recess the mounting plate flush with the boxed frame.
So, I cut out the frame, re-worked the steering box mount and welded it flush with the inside frame member with the nuts on the inside of the frame.
Will try to remember to take a photo of the finished mount the next time the engine is out.
Why would anyone in their right mind put a 1520cc Honda Goldwing engine in a '32 Ford Roadster? Better question is why not...; it's a really light car, probably isn't going to weigh much more than a fully dressed Goldwing with two fat people on it. :ROFLMAO:
The Brookville Roadster body only weighs 265 lbs.
The Honda 1500 engine and transmission weigh 285 lbs; the Ford Flathead and Transmission weigh 629 lbs. (no exhaust manifolds on either engine) Both put out 100hp. Goldwings are water cooled and have a reverse gear, so I think this is going to be a fun project. I'm not interested in building a go-fast racer or a show car. This one is going to be more of a fair weather weekend cruiser.
After a lot of back and forth, up and down I finally settled on the engine position.
Motor mounts are next. Have to cut out the old Ford mounts first.
I will try to keep this build updated, I tend to get busy building and forget to stop and take pictures.
P
PugetDude
I posted pictures of the motor mount fabrication previously, here is how they tie into the '32 frame rails
I elected to use the stock Honda tube frame mounts that tie into the lower engine mounts. They are sculpted to fit in behind the exhaust system and the left side has a threaded mounting tab that is used with an aftermarket shifter shaft support. Left side was easy, I just cut the mounting tabs off and built my own mounts to tie into the stock tube support.
Front:
Rear:
(Note the carpet padding spacer between the steering box and the exhaust.)
The right side was a different story. There wasn't a removable frame tube on the right side of a Goldwing...but there is on a Valkyrie. Bought one on eBay for $20 to try it- and it almost fit. The mounting tabs were in the right location but were 5/8" too narrow, they wouldn't fit over the rubber grommets. Also, the tube was about 1/4" smaller in diameter than the Goldwing tube. But it did tuck in behind the exhaust, so I cut two of the tabs off, fabbed replacements out of one side of a 2" x 1/8" wall square tube (it gave me a nice rolled radius to match the stock tabs) and welded it all back together. Had to add an inch to the front of the tube to get the mounts somewhat symmetrical. The Honda engine is offset about a half inch from side to side.
Used 3/8 bolts with grade 5 nuts welded to the bottom of the frame mounts.
The Honda engine mounts are isolated with rubber grommets. I can always add a piece of rubber between the frame mounts if necessary later. These bikes run really smooth so probably not going to be an issue.
Satisfied with the fit, so I bolted everything in position on the engine, clamped the mounts so they wouldn't move and welded them in place. Got lucky, have plenty of clearance for the steering column and shaft.
Driveline is next, going to be fun figuring out how to adapt to the ******* 15/16" x 23 spline 1-1/8" long stub output shaft. :unsure:
P
PugetDude
While I was waiting for the driveshaft shop to decide if they would build a custom driveline I decided to rework the exhaust manifolds. Goldwing exhaust manifolds are covered with heat shields, skid plates and mounting tabs. Thought if I could strip everything down to the basics they would look like headers. :unsure:
Removed the heat shields (got lucky, didn't break off the 6mm bolts) and then tackled the skid plates. They were plug welded to the lowermost exhaust pipe.
Ground out the plug welds VERY CAREFULLY with my M12 right angle die grinder, then wiggled the heat shields off.
When I got the heat shields off I was able to grind the welds off and smooth out the exhaust pipes.
Now came the real work....the Exhaust outlets were really small and pointed up and in. Couldn't use them as they were so I cut the ends off with the expectation that I could open them up for a stock 2" exhaust. Sounds simple enough?
This did not go as expected....
When I cut the ends off the left side, it revealed an internal baffle the full length of the collector. So, no way to get an expander in there.
Only way to remove it was to saw the collector off completely, split it down the middle and than weld it back together and onto the exhaust... then open it up for the 2" adapters.
The collector is really heavy gauge steel, and deeply convoluted. It was a real challenge to get it opened up enough to get an expander into it. They turned out a little rougher than I would have liked, but I was concerned about grinding through them trying to smooth them out. (I did burn through in a couple of spots welding the **** seams back together.)
After a coat of VHT primer and two coats of VHT flat aluminum paint.
Happy with the two hour job that turned into most of the day.
Driveline is next- mocked it up with a piece of PVC pipe. Looks like it's going to require an extensive frame modification, it runs straight through a crossmember.
P
PugetDude
Here's the Honda Goldwing output shaft.
It's a 15/16" 23 spline stub shaft. No one makes an adapter for it. Honda yoke/ u joints are non serviceable, and can't be replaced.
AZ Driveshaft was unsure about how to mate up to it when I went in to talk to them. I had the Honda Yoke, the Ford 8.8 Spicer flange and the U joints I had planned on using with the T-5/ Flathead.
It was late on Friday afternoon, so I Ieft them the parts and my sketch for the techs to look at on Monday.
On the way out I ran into one of the techs in the parking lot. Got to talking with him, showed him a couple of pics on my phone and told him the girl at the front desk was skeptical on whether or not they could do it.
His response was basically " hold my beer" :ROFLMAO:
Got a call back on Monday that he had figured it out. They machined the drive side yoke down to a press fit with a 1-1/2" heavy wall tube, and welded the joint. Stayed with 1-1/2" from the yoke to the carrier, then 2" from the carrier to the differential. It was a bit pricey, but I picked it up on Tuesday afternoon.
The carrier installation required me to modify the frame. Cut the old transmission mount out then decided to use the flanges off it to build the new carrier mount- had to cap the 1-1/2" square tube ends with something anyway. It needed to be as high as possible to minimize the angle between the Honda output shaft and the carrier. It's a straight shot from the carrier back to the Ford differential, only a slight horizontal offset. I used a piece of 3/8" plate to mount the carrier, it's welded to the flange plates I cut off the old transmission mount. Drilled and tapped 7/16-14, then welded nuts on the top side for additional thread engagement.
Next step was to replace the frame member I had to remove to accommodate the driveline. Had to offset it to clear the carrier mount, so I did the kerf/bend/weld/grind exercise on a piece of 1-1/4" square tube. IMG_20231012_163929779.jpg
Installed.
The way this worked out I won't have to much in the way of sheet metal modifications on the front floor or firewall. I may elect to cut the stock hump way down- the driveshaft is offset to the passenger side and it would be nice to have a bit more room for my EEEE feet in the pedal box.
I'll do a bit of turd polishing on my welds today then move on to sorting out the shifter and clutch/ brake pedals. The massive underfloor assembly I was using before is way too big and bulky for this build.
P
PugetDude
Nice work. Are you going to run a hood with top and sides so you can reveal the source of the unknown sound or just run a top?
Probably just the top. I like the look of the aluminum and chrome Goldwing engine sitting in the exposed engine bay. I am going to have to figure out a big polished aluminum air cleaner to replace the stock Honda plastic airbox. It has dual carbs, but they are transverse rather than in-line.
P
PugetDude
Circling back to the old fiberglass body for a minute,,, I did end up trading it for the steel front end parts I needed for the Brookville Roadster body. Back in May, before I headed up North for the summer.
Got a hit on my CL ad from a guy who didn't have any cash but had "parts and tools to trade" so I took a chance, loaded the glass body and drove 70 miles across the Valley to see what I could do.
Turns out 4.5 years as a guest of the AZ Penal System isn't conducive toward discretionary income. But he had a really nice '32 Coupe with a Corvette engine that was overheating uder a closed hood that he wanted to change out.
So, I got a really nice Grille shell with insert, a hood w/ Dan Fink Hinges, both hood sides (that I won't use) off his '32- we literally took it apart in the driveway. In order to make the trade more equitable he also included a Baldor buffer on a Baldor stand, and then at the last minute threw in all of his machinists tools that he no longer had a use for. (Starrett mics, sine plates, v-blocks, etc. And a big tote full of all made in USA end mills, drill bits, reamers, etc. Completely filled my Huot indexes and still have half left in the tote.
Nice guy who made a really stupid, life-changing mistake.
HogDude
Nebraska
Nice haul and a great story. I hope you have the opportunity to stay in contact with him. Sounds like you have some common interests and skills. It might help him to have a solid guy like yourself to reach out to from time to time if for no other reason than to just chat. As he goes about his daily routines some will judge him by his previous actions. At this point those are all "in the rearview mirror" and not who he is now. I recall something about casting the first stone. I can't.
Monza Harry
Windsor ON
Nice change of pace with the GW powertrain. I had considered that with a blower for a project I can't/couldn't afford. Low light, fun, and different was the plan. Looks like you are smashing down that door with this one! Your spline is likely a M24-23 that is an odd spline count as it is a prime number, I haven't run into this often [ok, ever] but in all fairness I only play with splines on my toys it's not part of my work duties. M24 is 0.94488" 15/16" is 0.9375" like many fitting pieces tolerances are typically +0/-0.***" so I would expect that male spline to measure around ~0.940" really, really close to your 15/16".
Couldn't the end of the existing (or a replacement [new or used]) drive shaft be cut off and grafted to your new one? Either way looking nice, I'll be here same bat time same bat channel! Harry
P
PugetDude
That's what the driveshaft shop ended up doing. They machined the OD of the Honda driveshaft yoke to a press fit on a 1-1/2" heavy wall tube, pressed it on and then welded the joint. Then, standard Spicer components downstream to the Ford differential.
P
PugetDude
Spent most of the day today working on a new driveline tunnel. The Bitchin Products floor pan had a wide shallow tunnel that just didn't work for this application. It was too wide and not deep enough. It's a bit hard to see in the pictures but there was only about 1/4" of clearance on the floor pan, I wasn't comfortable leaving it like that. I opted for 1-1/2" of clearance all around instead. Probably more than I needed, but it still leaves me a lot more room inside. This first piece of CADboard ends where the frame recess would normally be on a '32. I discovered I could eliminate the recess completely when I implemented next- level FEA (F*ckup Expectational Avoidance) and mocked it up. I will have to do some kind of removable panel in the event I ever need to remove the starter. Only have about 3/8"-1/2"" of clearance between the CADboard and the starter.
One benefit this Honda engine gave me is the opportunity to do a completely flat firewall, with more legroom, and a lot more width in the driver's side footwell- if I reworked the tunnel.
I dug out a piece of 18 gauge steel, and started bending a cone out of it, using a piece of pipe, brute force, and ignorance. I know I could have looked up how to layout a cone frustrum, spent an hour with a piece of butcher paper making a pattern, etc... but the shape wasn't that critical so I opted to just dive in.
When I got it close to the final dimensions I needed and it looked like it might actually fit, I bent the flanges on my little homemade sheet metal brake, then took the plunge and drilled out the spot welds on the floorpan. Didn't have a spot weld cutter so I use a 1/8" pilot drill and then a sharp 1/4" cobalt bit to drill out the spot welds. Surprisingly, it came apart really easy. .
The new tunnel only needed to be 4.5" wide, so this is opening up up a ton of room in a 90+ year old car that is notoriously tight in this area.
Here's the original tunnel and the new one side by side for comparison. They both protrude about the same length into the car. l built the new one to bridge the gap whereas the Bitchin Products floor pan/tunnel stops about 4" short of where my flat firewall ended up- I don't need the 4" recess with the Honda engine.
I built the new tunnel in three pieces- the slight conical transition off the firewall, the steeper main tunnel and the rounded end cap. It took a lot of tack welds and a lot of grinding to get it where I wanted- but I am happy with how this turned out. The welds you see on the mounting flange were all done from the inside- I didn't want to warp the flange by pouring a lot of heat into the joint. I did these in stages and let them cool in between.
I did **** joints on the three cone sections, welded both sides for strength and to give me enough thickness to blend the weld transitions. They cleaned up well, used a combination of 4.5" 40- grit flap discs, 2" 36 grit sanding discs, and a 2" scotchbrite surface conditioning disc to smooth out my welds on the top side. My little Milwaukee M12 right angle die grinder got a real workout on this project. No way I am showing the underside....but everyone probably already knows what a hundred+ tack welds look like, anyway.
Next step is to fill in the void left by removing the wider tunnel. It has an offset flange at the top for the lap joint that ties into the firewall. I'll have to fab filler pieces for both sides of the tunnel as well- and then figure out how I am going to secure the flat firewall to the cowl... and make the assembly removable...
zmotorsports
Northern Utah
Awesome work on the tunnel Scott.
I was working with a guy over the weekend texting back and forth as he had some questions and it hit me, what about a transfer case adapter for the Honda output spline. I believe this is a 23 spline count adapter that could be modified to work.
Just a thought.
P
PugetDude
Just a thought.
Thanks, Mike. I had looked at that adapter online last week, never could find detailed specifications to confirm the bore diameter. Google has really changed from being a great resource for detailed product information to product advertising overload. "Does this fit? Enter your vehicle information... this DOES NOT fit your 1932 Ford..." :unsure:
Anyway, AZ Driveline did come up with a solution. It looks like it is going to work well, but is still utilizing the non-servicable Honda Yoke. Supposedly this one only had 20k on it so I am hoping for the best.
Old Man Roger
Palm Coast Florida
Cool project.
There was guy on MiniBuggy.net that put a fuel Injected GW motor in one of those little Chinese vans. Unfortunately the site has been down for months. I suspect that little van probably did wheelies with the rear engine set up.lol
shortykorte
Tallahassee, Fl
Now that’s an update.
Great minds think alike. A GL power hot rod.
I decided 3-4 yrs ago to use my Valkyrie drivetrain in a reverse trike hot rod.
6 cylinder 6-pack.
I have a complete drop axle front end with GM rotors and a baby fiberglass 32’ radiator shell. Just need a shop I can work in and 6 Saturdays a week.
I’m so looking forward to studying your build and seeing what will be a great outcome.
P
PugetDude
6 cylinder 6-pack.
Shorty, I am thinking that shiny Valkyrie chrome exhaust might fit in place of the Goldwing exhaust I just modified... but that's way down the list; gotta get it running first.
shortykorte
Tallahassee, Fl
Have you heard an uncorked Valkyrie? Awesome. Almost sounds like a SB Chevy. A good friend of mine did his. I just have the end plate out of mine. Slight rumble so you can hear the silky smooth engine.
Valkyrie Riders has a lot of great information on exhaust, adding the super charger (wink, wink) along with other great maintenance and performance tips.
Thirdyfivepickup
Portage, Indiana
ok. When I first read about this on the "what weird stuff have you done to a car" thread I thought... "this may be the dumbest thing I've ever heard of.
Now I'm here and I really cant wait to see more. The benefit of the tiny trans tunnel... the unique look of the engine... the exhaust... the shop... the fabrication.
Win/win/win/win/WIN!!!! LOVE IT!
P
PugetDude
Since I needed to go drive across town to get a sheet of 16 gauge steel for the flat firewall, I elected to work on closing out the footwell first. The firewall is going to need something to bolt to on the bottom and the floorpan needed support where I removed the old shallow tunnel.
The gap at the front measured a little over 4 inches wide... any commercial hot rolled angle would be overkill for this application. I could cut and bend it out of sheet steel on my brake, though...but 18 gauge is the heaviest I have on hand.
If only someone made a 2"x 4" x 14-16 gage angle... :unsure: .... that would work perfect.
...like this one I got from a metal building contractor. 6' long. Covered in dirt from
laying out in the weather in his boneyard. Free. A thing of beauty and a wonderment to behold.
It didn't take long to cut and fit both sides. They are secured with 1/4-20 Rivnuts to the floor pan and the tunnel flange. Compound angles on each end to follow the body lines and the tunnel were the only challenging part of this. (Glad this piece was twice as long as it needed to be.)
Both sides fitted. Happy with all the increased flat real estate, both vertical and horizontal. Pedals, shifter and e-brake should all be a lot easier to install .
These angles underlap the bottom tunnel flange to support it. They sit on an offset lap flange so everything is fairly flat. I added the offset to the filler panel with my little sheet metal brake.
Wanted them to **** up flush to the vertical tunnel flange to keep everything in the same plane against the firewall.
Firewall is next. Going to try rolling a few beads into it to stiffen it up. Have never used one before, empirical evidence suggests I should probably should buy a sheet of 16 gauge twice as long as it needs to be. Thanks to @LXCam for the use of the bead roller and to @TimeWarpF100 for a meeting point halfway. Will look for a sheet of steel on the way home from North Phoenix tomorrow.
More to come.
